new video from Well Tempered blog
0 Members and 1 Guest are viewing this topic. Read 5579 times.
gagamut
« on: 15 Sep 2015, 01:22 am »
https://welltemperedlab.wordpress.com/
the video is show 'how to suspend a WT LTD tonearm'
sebrof
Re: new video from Well Tempered blog
« Reply #1 on: 15 Sep 2015, 01:35 am »
Looks like that same procedure for any of the newer arms as well (the Amadeus)
ADiG
« Reply #2 on: 15 Sep 2015, 07:12 am »
double twist for anti skate?  :o
rob400
  • Versalex and Audio Note for the rest
« Reply #3 on: 15 Sep 2015, 05:04 pm »
My thoughts exactly. This is not how I set mine up. Single twist only!
threadkiller
« Reply #4 on: 15 Sep 2015, 05:17 pm »
The kiwis are below the equatorial line-hence the double twist to balance out the hemispheres...
rob400
« Reply #5 on: 15 Sep 2015, 05:32 pm »
lol. Joking aside either the kiwi method or the single twist set up has got to be wrong.
mannikman
« Reply #6 on: 15 Sep 2015, 05:43 pm »
It would be good to confirm as you say folks. The people I know this side of the pond with WT's all say single twist...
mannikman
« Reply #7 on: 15 Sep 2015, 05:45 pm »
Mind you take a look at this from the website
https://welltemperedlab.files.wordpress.com/2010/06/rear-tone-arm-lp-28ci9151.jpg
That looks like a double twist to me…… Mind you I guess at the end of the day we should just try it and see how it effects the sound...
rob400
« Reply #8 on: 15 Sep 2015, 06:32 pm »
That looks like a single twist to me when I blow it up. Loathe to do anything to my Versalex/LTD my XV1s sounds great with one twist.
threadkiller
« Reply #9 on: 16 Sep 2015, 12:52 am »
As in life, one twist is right.
Rob, keep your hand off..
gagamut
« Reply #10 on: 16 Sep 2015, 08:39 am »
mine is single twist too,
sebrof
« Reply #11 on: 26 Oct 2016, 06:13 pm »
My table was set up by my dealer before I bought it, and he did the single twist.
Today I couldn't leave well enough alone and went double twist. I'm not sure it's a feasible way to go. With single twist, when I rotate the ring to adjust azimuth, the arm moves nice and smoothly back and forth. With double twist, the junction where the strings overlap moves with the ring. IOW, since there's a double twist the strings can't pass each other easily, so the arm moves hard to one side and then jerks as the strings release. And once I moved the ring/azimuth, I couldn't really get it back straight again.
Needless to say I'm back to single twist.
Topshelf
  • A Well Tempered fan and lover of Tron electronics
« Reply #12 on: 25 Feb 2017, 08:36 am »
To twist or not two twists! I am having problems with too much bias and I am wondering if two twists would help this issue. I am going to start a new thread as I need guidance.......... The other factor that must come into effect is clockwise or anticlockwise whilst holding the cart and viewing the paddle up the arm.
Topshelf
« Reply #13 on: 25 Feb 2017, 12:47 pm »
No need for another thread as the moderators have moved my "setting up a classic" to the well tempered group of contributors. I must admit I do like that pulley system for the later arm, I keep telling myself I have the E type jaguar of TT's because it's a swine to keep control of whilst having too much fun, a slightly sloppy backside but  it's so beautiful to look at. Why ever would I want an XJS or XJR?
