HELP NEEDED! New Well Tempered Classic Owner
0 Members and 2 Guests are viewing this topic. Read 4492 times.
audiojem
« on: 11 Sep 2015, 07:27 pm »
Members
I am looking for the following help, info and sources.
I just bought a used WT Classic previous owner did not have any paper work so I'm looking for the following items.
Manual /Set Up Guide
Protractor
Any other forms of paper work or Items that might of come with table when brand new.
Source for main bearing silicone fluid, Dow 200 50cst, I have the arm fluid.
Source for new belt.
My email is [email protected]
Thank You For Your Help In Advance.
Jeff
GentleBender
Re: HELP NEEDED! New Well Tempered Classic Owner
« Reply #1 on: 11 Sep 2015, 07:39 pm »
I'm sure there are plenty of people here to help, but here is what I can offer. http://www.vinylengine.com/library/well-tempered/classic.shtml You will have to register to download. :thumb:
audiojem
« Reply #2 on: 11 Sep 2015, 08:24 pm »
GB
That was a great start, People keep them coming please!
Thank You
audiojem
« Reply #3 on: 12 Sep 2015, 10:44 pm »
Source for Dow 200 50cat silicone fluid would be big help, I need 8oz bottle not gallons.
Thank You
Jeff
audiojem
« Reply #4 on: 12 Sep 2015, 10:46 pm »
Dow 200 50cst For Main Bearing.
Yes I know I can use Mobil1 etc... but do not want to swap out.
Jeff
GentleBender
« Reply #5 on: 13 Sep 2015, 11:36 am »
Dang! Not much going on here. I found this article discussing your exact issue http://www.audiokarma.org/forums/archive/index.php/t-582950.html
Looks like they went here and bought samples. Www.weknowemulsions.com
I found many choices on eBay if you want to even try different viscosities. http://www.ebay.com/sch/i.html?_ftrt=901&_fsradio=%26LH_SpecificSeller%3D1&_sop=12&_sadis=15&_stpos=32608&_odkw=&_saslop=1&_fss=1&_dmd=1&_sasl=Scott+at+Scientific+Concepts+&_osacat=0&_ipg=50&_ftrv=1&_from=R40&_trksid=p2045573.m570.l1311.R-1.TR12.TRC2.A0.H0.Xsilicone+fl.TRS0&_nkw=silicone+fluid&_sacat=0
I have no experience with the Well Tempered turntables, so I can't recommend what works best.
gagamut
« Reply #6 on: 14 Sep 2015, 02:27 am »
i have a well tempered protractor,but it's for well tempered reference,so i don't know is it suitable for your classics,if you want ican sent to you :thumb:
SteveFord
« Reply #7 on: 14 Sep 2015, 11:13 pm »
That should be the same difference.
If I'm not mistaken, the Reference had a carbon fiber arm and the Classic had aluminum but everything else was the same as far as dimensions.
audiojem
« Reply #8 on: 15 Sep 2015, 12:55 am »
Still looking for solid sources for New Belt and Bearing Silicone.
gagamut
« Reply #9 on: 15 Sep 2015, 01:16 am »
bearing oil should be 5W-50,
mgsboedmisodpc2
« Reply #10 on: 15 Sep 2015, 03:48 pm »
well are you up and running yet audiojem ..
post some pics of your table,
what cart are you running
what mat if any are using.
which platter are you using e.g. is it clear or not
