0 Members and 1 Guest are viewing this topic. Read 2532 times.
..,I like the bass of speakers because i think there is some directivity there that stereo imaging reproduces,am i wrong?
Since this is the lab, I say the discussion shouldn't shy away from the science and the facts. Bass in a small room* has been well studied but largely ignored by the audiophile community (see Toole, Geddes, Blauert, etc). The whole problem involves the modal region between the first mode and the schroeder frequency. The problem really lies in the fact that the Schroeder frequency (fs) is typically well above the point at which you crossover to subs (say ~200hz +/- 50hz). I think for small rooms, multiple subs and well thought placement is undisputably the king, and there is mucho evidence to prove this. However, typically you are going to cross these subs around 80hz to avoid localizability. This leaves the region from 80hz to fs the main problem to tackle with room acoustics. It's my humble opinion that it's this area, not the true bass below 80hz that leads many audiophiles to believe that main speaker bass is better than subs. Because integration is a bit trickier when there are modes and valleys in the area you are trying to cross, and the human ear tends to associated higher harmonics with the fundamental in bass frequencies. Fortunately traps can typically help here.Take for example, you are using two subs crossed at 80hz with a LR 24db/oct slope. But you have a major room mode at 160hz that spikes 20db. Suddenly your subs become localizable even though they are crossed at 80hz, but not because of the bass below 80hz but the mode an octave above. Further, I think if you are not taking real measurements of your room and are coming to conclusions based on listening only you are highly misguided. I wouldn't trust myself let alone some "authority" on the internet espousing their experience without the measurements to back it up. [you here is general you, not you in particular GG, just an FYI, this isn't a pot shot against anyone in particular]* What I mean by "small room" is in the definition used in acoustics, meaning a living room rather than a large concert hall. edit: there are lots of good discussions about the science of room acoustics freely available on the internet in addition to the books by Toole, Geddes, etc. http://www.linkwitzlab.com/rooms.htm is one.
