0 Members and 1 Guest are viewing this topic. Read 8469 times.
You might want to consider another cart even if it's only a backup. Get a nice MM w/replaceable stylus. The DV10X5 is a step down IMO. The pitfall is to abandon the OC9 before you really know what it can do. 30 hours isn't enough to tell, not on an OC9. Regards,neo
Not to derail the thread, but I have to strongly disagree here. 30 hours for a cartridge should be plenty of time to make a cart listenable. While there will certainly be changes up to 100 hours, you should have a healthy indication of what the OC9 "can do" before that point. The Dynavector 17D3 which replaced it, and actually has the same MSRP (the OC9 gets heavily discounted at purchase), completely outclassed it hour one.100 hours of vinyl listening is a significant amount of time for most of us. To waste 5-10 percent of the carts life (depending on how well one cares for records and stylus) on waiting for any cart to start sounding decent seems like a waste of time. Just figured I would try and save the OP the hassle of having to waste 100 hours of his listening time, hoping he eventually likes the sound of a cart.
But you'll never really know, will you?"When I get back into analog a couple years back, I bought into the hype. Everyone, including even Keith Herron (Herron Audio), was talking about how excellent the OC 9MK3 was." Should we value your experience over Keith Herron, or try to understand why your results were less than satisfactory? Seems ironic - you say a SUT might take up to 100 hrs, but not a cartridge. neo
Generally, IME, I have never had a component go from really bad to good with break in. I usually appreciate the sound, and it gets better. The AT was just flat out poor from jump street. As for valuing people's experiences, on a subjective matter, based on their profession, I'd have to disagree. Do you own Herron gear? What if you bought his amps, or preamp, and didn't care for the sound? Does that make you wrong, because Herron designed it, and his experience means more than yours?Have you sold any gear because you didn't like it? Well, you were wrong to do so, because the person who designed its opinion is more valid than yours.Lets also not forget that Herron is trying to sell a phono preamp. Demonstrating that you can get good sound from his phono, with a reasonable cart, seems like a great business strategy to me. And, while I did note, that perhaps my results were because of a poor phono preamp mismatch (I was using a Pass Labs XP-15 at the time), changing out phono preamps to accommodate a cartridge that frequently retails for 40-60 percent (wonder why?) off its MSRP seems absolutely asinine. Why spend hundreds, or thousands, and go through all that trouble to make a decent cart sound marginally better? Not worth the trouble, when there are plenty of options that might more readily bring satisfaction.In any event, to each his own. Glad you like the AT. Hopefully the OP finds happiness with his system.
