BP-26 / MPS-2 - Remote powering ?
0 Members and 1 Guest are viewing this topic. Read 871 times.
AJAudio
  • The sweet sound of music...
« on: 4 Sep 2015, 05:44 pm »
Hi,
I would like to be able to "remote power on/off" the BP-26/MPS-2 combo.
If I were to use a relay (mechanical or solid-state) to "switch" on/off the power to the MPS-2, would that cause problem in the long run or would this method be approuved by Bryston ?
Take care!
  • The Demo is Everything!
    • http://www.bryston.com
Re: BP-26 / MPS-2 - Remote powering ?
« Reply #1 on: 4 Sep 2015, 05:54 pm »
Hi,
Take care!
I do not think there would be an issue AJ but check with Mike - [email protected]
james
AJAudio
« Reply #2 on: 18 Sep 2015, 04:33 pm »
Hi all,
For those who may be interested in doing something similar, Mike got back to me today.
Here is what he answered:
Providing the power is being switched using a relay based AC switch, there should be no performance penalty.  However, I can’t say the same for solid state switches; some are quite transparent while others may add noise and/or distortion to the waveform...
So I guess I'll go in the "mechanical relay" direction then.
Thanks Mike!
Take care!
AJ
