BR2 Remote - IR-LED frequency and wavelength
0 Members and 1 Guest are viewing this topic. Read 970 times.
AJAudio
  • The sweet sound of music...
« on: 3 Sep 2015, 02:58 pm »
Hi,
What is the center frequency and wavelenght of the IR-LED used by the BR2 remote ?
Is it standard 38Khz  and 930–950nm ?
I need to find a good matching IR receiver/demodulator.
I want to use an Arduino board to decode the BR2 unused button (in my setup) to control some LED strip lighting...  :-)
Take care!
Mike Pickett
Re: BR2 Remote - IR-LED frequency and wavelength
« Reply #1 on: 3 Sep 2015, 03:27 pm »
Hi:
The IR emitter is a Vishay TSAL4400.  It's peak wavelength is 940nm, and we do operate it a 38K.
Mike
AJAudio
« Reply #2 on: 3 Sep 2015, 05:05 pm »
Hi Mike,
Thank you for the info.
I just remembered that you post most of your schematic on your web site...
Looking at the schematic for the BP-26, I can see that you use the Rohm RPM6938 as the IR receiver/demodulator.
I'll just order a few of those for development and testing.
Are you able to provide me with the protocol specification used by the BR-2 IR stream ?
Thank you for your time.
Take care!
AJAudio
« Reply #3 on: 4 Sep 2015, 06:35 am »
Hi Mike,
I managed to reverse engineered the protocol on my own.
Thanks any way!
(I have a rough-prototype working on an arduino.  Cool!  :-))
Take care!
