Amber or Euforia
0 Members and 1 Guest are viewing this topic. Read 5794 times.
Atlplasma
  • Just off the boat
Amber or Euforia
« on: 3 Sep 2015, 01:15 am »
So how do Amber owners feel about this new introduction? I'm not trying to stir up a controversy--just curious about these two units since they are both DSD and similarly priced.
wisnon
Re: Amber or Euforia
« Reply #1 on: 3 Sep 2015, 05:50 pm »
Amber may be going away. Ask the Lampi guys.
Gopher
« Reply #2 on: 3 Sep 2015, 05:56 pm »
In terms of SQ, the Euforia will be the superior sounding DAC using our own DSD engine instead of a sabre.  The cost, however, it is USB only with NO PCM support.
Atlplasma
  • Just off the boat
« Reply #3 on: 3 Sep 2015, 05:59 pm »
Amber is DSD only as well, right? You would need to convert PCM to DSD (say with JRiver).
Berto
« Reply #4 on: 3 Sep 2015, 06:36 pm »
Nope, Amber is both, no need to convert.
Atlplasma
  • Just off the boat
« Reply #5 on: 3 Sep 2015, 09:01 pm »
Thanks for clarifying.
Muser
  • I post at audiogon as muser, and write for PFO.
    • Positive-Feedback Online
« Reply #6 on: 3 Sep 2015, 09:09 pm »
Gopher:
A friend in England said the Amber is going away. Is that a) true; b) just true for Europe; or c) none of the above?
If it is going away is there a time table or is that TBD?
In advance, thanks
Larry
bmoura
« Reply #7 on: 4 Sep 2015, 12:12 pm »
The Euforia gives you a version of the Lampizator direct filtered DSD system for half the price of the DSD DAC with Jupiter caps.
That should be quite attractive I'd think.   :)
http://www.lampizator.eu/Fikus/NEW!_DSD-Euforia_DAC.html
http://www.positive-feedback.com/Issue76/lampizator_dac.htm
Gopher
« Reply #8 on: 17 Sep 2015, 03:48 pm »
Gopher:
In advance, thanks
Larry
The Amber is not going away, however some changes are being made to it to try to retain/improve upon the existing sound utilizing components we can get from a reliable and consistent supplier.  We expect to resume taking orders for Ambers within the next week or two.
wisnon
