SP3 latest firmware... where is the bass???
0 Members and 1 Guest are viewing this topic. Read 1991 times.
BrystPlug
« on: 2 Sep 2015, 03:27 pm »
I tried to update my firmware last night.. What a disappointment, where is the bass??? Is there any tweak to set to put it back where it was? On the 2014.07b it was fantastic, on the latest, horrible :( like i lost every good thing
Anyone else experienced the same? Configuration is for stereo, so no sub/small setting for speakers.
Thank you
ragg987
Re: SP3 latest firmware... where is the bass???
« Reply #1 on: 3 Sep 2015, 09:24 am »
Do you mean it is currently set to small speakers? If so you need to set to large if you do not use a sub.
I had previously updated firmware versions and noticed that some of my previous configuration was reset to defaults so needed to re-apply my settings manually.
BrystPlug
« Reply #2 on: 3 Sep 2015, 11:47 am »
oh :)
I will try to reput the newest firmware and retry it...  thanks for the tip
stanb
« Reply #3 on: 3 Sep 2015, 04:22 pm »
Hi BrystPlug,
A previous (old firmware) bass levels were too high and were adjusted down to conform to Dolby and DTS certification requirements.  If you need to adjust bass levels back up, it can be done through the menu:
SOURCE SETUP-->SPEAKR LEVEL-->SUB (up to +/-12dB)
That is per source. Bass and LFE can also be adjusted globally in SYSTEM-->SETUP-->MISCELLANEOUS menu:
BM DITRIM   (range -40 to +22dB, this is Bass Management LFE Digital Input trim)
BM AOTRIM   (range -40 to +22dB, this is Bass Management Analog Output trim)
BM DITRIM applies only to SPDIF,Optical and HDMI sources,
BM AOTRIM  controls the analog SUB channel output level.
You may find more support SP3 links, documentation and application notes  on:
 support.bryston.com/forum/viewtopic.php?f=29&t=195
Stan B. (Bryston)
BrystPlug
« Reply #4 on: 3 Sep 2015, 08:38 pm »
Was it before 2014.07b ? (The old firmware) it was on this one, the bass in stereo was superb, upgrade to latest firmware and voila, no more bass. Thanks for guideline in the menu!
stanb
« Reply #5 on: 4 Sep 2015, 06:33 pm »
There was a bass adjustment 13.5dB up for digital and hdmi inputs in rev 2014.05 and 06b, (which was excessive)  then there were adjustments correcting it in rev 2015.04a
Stan B. (Bryston).
