Audio/Video Gear and Systems
The Vinyl Circle
woodsyi
Marantz TT-15 on the way, need phono preamp under $200
0 Members and 1 Guest are viewing this topic. Read 1803 times.
TKonrad.NOLA
Restricted
20 Aug 2015, 11:13 pm »
Any assistance would be greatly appreciated.
neobop
BIRD LIVES
Re: Marantz TT-15 on the way, need phono preamp under $200
21 Aug 2015, 10:20 am »
Hi,
I haven't heard it, but from all reports this is the hands down winner in that price range:
https://emotiva.com/products/pres-and-pros/xps-1
neo
2gumby2
Reply #2 on:
21 Aug 2015, 12:39 pm »
PM sent.
electricbear
Reply #3 on:
21 Aug 2015, 01:44 pm »
The Emotiva does sound good for the $. It's also quite flexible with the ability to do both mc & mm. It's similar to the iphono but a lot cheaper.
sunnydaze
Reply #4 on:
21 Aug 2015, 06:35 pm »
Expand your budget by 100 bux and get the Vista. It's worth it.
http://www.vista-audio.com/products/phono-1mkII/index.htm
Adjustable unit that offers nice flexibility and great sound that competes sonically with units up to $1000, IMO. And Boris is a great guy to deal with. Google and find all the positive comments.
Or keep looking for a used one to appear. It will be $200 or less.
Good luck with your search.
yeldarb
Reply #5 on:
22 Aug 2015, 04:43 am »
I have an Emotiva, on my second system. It is pretty darn good. And I think they will let you send it back, if you don't like it. If not using MC, you might look at the new Orbit
pre.
Volunteer
I reject your music, and substitute my own.
Reply #6 on:
25 Aug 2015, 03:05 pm »
Aren't you kinda cutting yourself short by limiting your budget by $200?
If I had that turntable, I would spend more on the phono pre-amp.
The Vinyl Circle
woodsyi
