no response in MM clicking on Artist, Album, Genres etc
0 Members and 1 Guest are viewing this topic. Read 2609 times.
Marius
Hi all,
Never really tried it, but after clicking Artist, Album, Genres, Album Artist in the MM left column Drive list, nothing happens other than a blank space. Not even the 'loading' we get to see when loading a new drive or folder after clicking it.
What's supposed to be listed seems obvious, but does it work for anyone?
Please share if it does.
Playlists works fine.
Marius
  • The Demo is Everything!
    • http://www.bryston.com
Re: no response in MM clicking on Artist, Album, Genres etc
« Reply #1 on: 20 Aug 2015, 10:59 am »
Hi
Have you loaded the data base with your albums under Artist View?
james
Marius
« Reply #2 on: 20 Aug 2015, 01:10 pm »
No I hadn't James. Will try again.
Ive had my share of issues with the song and artist view buttons, so i gave up and never used those.....
Sorry, that was too obvious  :scratch:
afraid its going to take a while, been like this for 5 minutes already:
will give it some time, thanks for the  subtle 'hint' ;0
Hope that Chris will implement the Album view again and overcome the MM issues we've had with that. Browsing the Cantata Album view, or iTunes for that matter is still something id love to see in MM.
Marius
Hi
james
Marius
« Reply #3 on: 20 Aug 2015, 01:20 pm »
well,
no such luck:
Marius
Dave Jameson
« Reply #4 on: 20 Aug 2015, 05:20 pm »
Hi Marius,
Which firmware revision are you using? I just recently had a similar problem with accessing data from my internal SATA drive. The only solution for me was to revert to S2.16 2015-06-19 (I had been using beta firmware previously which has its own potential problems). Also strange was that my BDP2 then took a very long time to initially update its database. But it's been perfectly fine since then. So, maybe try changing the firmware?
Just an idea anyway.
DJ
unincognito
    • bryston.com
« Reply #5 on: 21 Aug 2015, 12:11 am »
well,
no such luck:
Marius
If your running a beta/testing build would you mind placing it in service mode so we might see why it isn't working?
Marius
« Reply #6 on: 21 Aug 2015, 06:19 am »
Hi Chris ,
Sure, thanks for having a look. I had to restart the Bdp for it had become totally unresponsive. In fact, it still is.....
Maybe wait a few more minutes after restart for it to settle completely. I'll let you know.
Marius
Marius
« Reply #7 on: 21 Aug 2015, 06:28 am »
Hi Chris ,
From my iPad I can click on any command, but the Settings button hangs.....
Have to kill the window and reload MM.
edit: just tested this, it only hangs in portrait mode, Landscape works fine. Has got to do with the responsive automatic window sizing? On desktop with a smaller window, the settings window pops up fine.
Seen this before, maybe not related. Otoh, I've never been able to create the artist and song views either, so maybe they're related after all?
From desktop mm responded correctly, no problem connecting to dashboard/services: Id 14.
Marius
unincognito
    • bryston.com
« Reply #8 on: 21 Aug 2015, 02:30 pm »
Hi Marius,
Is the unit still on? or has the service id changes?  it might be best to email me as i'll see the message sooner
Marius
« Reply #9 on: 21 Aug 2015, 03:00 pm »
still on, but became unresponsive again after trying to build the artist view DB.
Ill restart again. still id 14
Hi Marius,
