gain of 1V in 9B SST
0 Members and 1 Guest are viewing this topic. Read 705 times.
emajluf
  • Good Vibrations!!!
« on: 17 Aug 2015, 07:59 pm »
Hello fans of Bryston.
I will appreciate the help of you.
Its posible select Input Sensitivity switch 9B in gain of 1V for unbalace inputs or single-ended (but with balanced cables), specifically only when I connect source a DAC IDSD Nano IFI which has an RCA output of 1.6 volts. This is low compared to normal outputs 2 volts and so too must turn up the volume to the pre / pro Bryston SP2.
I have a pre / pro Bryston SP2, which connect to 9B with all balanced cables, but the sources are connected to SP2 are all single-ended RCA cables.
The sensitivity switch, you must leave 1V or 2V? generally.
Enrique
