***SOLD*** FS: Furman SPR-20i AC Power Voltage Regulator/Conditioner * MINT *
0 Members and 1 Guest are viewing this topic. Read 629 times.
iamjaymo
SOLD...Up for sale is the Furman SPR-20i.  It is a stable power regulator/conditioner. Provides an ultra-stable 120 VAC supply from low or high voltage sources. Cool running, noise free technology allows placement in critical listening environments. Linear Filtering Technology dramatically reduces differential AC line noise. SMP non-sacrificial surge suppression with Extreme Voltage Shutdown.
Front panel digital LED meter displays input voltage or output current with toggle button. 20A capacity, 12 Regulated and Linear Filtered outlets, Telco In/Out, 3 pairs coaxial connectors (Universal Coax).
Technical Specifications
AC Current Capacity: Input - 20 Amp capacity required, Output - 12 - 20 Amps RMS (19 Amps continous & 114 VAC).
AC Voltage Regulation: Provide AC regulation for a continuous output of 120 VAC (± 1.0V typically).
Linear Noise Attenuation: Transverse (Differential) Mode: > 40 dB from 10 kHz - 100 kHz, > 80 dB from 100 kHz - 1GHz (Linear attenuation curve from 0.05 - 100 ohms line impedance), Common Mode: > 75 dB, 10 Hz - 50 kHz, > 40 dB 50 kHz - 1 MHz.
Outlets: 8 linearly filtered - rear panel, 4 Linearly filtered outlets with additional ultrasonic filtering for digital or video components.
Transient Voltage Surge Suppression: 120 VAC - Series Multi-Stage Protection - Non-Sacrificial with Zero Ground Contamination
Shutdown Range: 135 VAC ± 5 VAC
Dimensions: 5.75H x 17W x 15.63D inches (Standard 3 rack unit height without feet)
Weight: 31 lbs
Power Consumption: 12 Watts for display and control circuits independent of actual load
Safety Agency Listing: C-ETL
MINT condition, not a scratch and will ship in the original box with original 20 amp power cord.
Original MSRP was $1600.  Paypal only (I will cover the fees).
« Last Edit: 13 Aug 2015, 06:50 pm by iamjaymo »
iamjaymo
Sold, thanks.
