0 Members and 1 Guest are viewing this topic. Read 7828 times.
Sub-sonic filter- can it be disabled? (my sub has one)Crossover-can it be disabled? (av pre-amp has one)If ss filter & crossover is disabled- any CPU resources left over to have 5 or 6 filters?Is left & right independent? (ie like the BFD, you could have two different subs/differently EQ'd)Radio Shack corrections built-into the software? (enter in raw values and it corrects)? able to enter the full 100-odd sine wave tones into the PC program to get a finer graph (instead of the 21 point excel/radio ...
Does the computer have to be in the same room connected to the system if you use a test cd and RS meter?Is the xo only low pass? What slope?Thanks,
You said the values for radio shack meter aren't corrected with your software. I understand a calibrated mic doesn't have to have the inputted values corrected (ie perhaps with your "deluxe bundled mic" kit) However when using the RS meter- if you enter the reading from the 20hz tone say on the RS meter display - 70dB, then according to the "correct" RS correction values it should appear on the graph +7.5dB =77.5dB? If your software does not adjust RS inaccuracy then inputting 70dB will be result in a inacc ...
Cool Product Idea!! Can I vote it starts off with an introductory price of $295 for everyone; even those without ACI subs?
Hi Mike,I just thought I would make two suggestions/requests for the R-DES:1) Variable slope on lo-pass xover; from 6dB/oct to 48dB/oct (min)2) Hi-Pass xover w/ variable slope; from 6dB/oct to 48dB/oct (min)It would be very helpful to have the variable high pass out so the main speakers get relief and the ultra steep slope would make the transition smoother and less noticeable.Thanks for the great product.
The DCX is almost $200 more (unless I'm looking at the wrong information). It is also targeted towards a pro audio consumer and (from what I understand) is not the most user friendly piece of gear. I think some people could really benefit from a user friendly product that does what Mike's new product will do.
