Plays DSD: NEW LH Labs GEEK PULSE Desktop DAC & Headphone Amp for $295 vs. $999
0 Members and 1 Guest are viewing this topic. Read 3479 times.
vaprotennis
I have a few of these BRAND NEW GEEK PULSE UNITS with all original packaging. If visiting the website you will see they are "sold out" and have a list price of $999. These can play DSD (Direct Stream Digital) which is the newest high resolution format.
My price is $295 which includes a LH Labs USB Lightspeed Cable, all original packaging & shipping to US 48 states & includes (list price of $99 on the website)
My Buyer/Seller ratings are high on eBay and elsewhere. I enjoy AudioCircle and the excellent posts so starting here first. This is a great price (which is less than the original pricing during and at the end of the campaign).
Here is a review: http://headphone.guru/geek-pulse/
LH Labs Website:  Description & Specifications
Geek Pulse is the world's most powerful 32/384 kHz + DSD128 desktop DAC and 3000 mW headphone amplifier.
Geek Pulse is Designed to be Different. Instead of just barely getting the job done, it goes the extra mile to get the job done well. Very well. So well that there's no other DAC that can do what it does without having to pay three times the price.
Specs
USB Audio Class 2.0 input with other 4 digital audio inputs all converted to 3L buffered I2S signal, then send to DAC IC
Full balanced current output then transconductance amp then summing up output amplifier
Two audiophile grade low jitter TCXO with super quiet power circuit and mu-metal shield
DAC IC: ESS9018K2M
Digital Inputs:
One USB 2.0 Type B Female
One set SPDIF via TOSLINK (JIS F05 Female)
One set AES/EBU (AES/EBU input compatible SPDIF signal by Adapter)
Two set SPDIF via RCA Coaxial
Supported Native PCM format: 44.1, 48, 88.2, 96, 176.4, 192, 352.8K, 384 kHz in 16/24/32 bit
Supported Native DSD format: 2.822, 3.072, 5.644, 6.144 Mega Hz / 1bit (via USB 2.0 Input) Support both DoP standard 1.1 and Native DSD (requires ASIO driver)
Patent Pending: 3L buffer by Light Harmonic Dual loop re-clock for all digital audio inputs
Digital Filter: Two mode selectable: Time Comprehension Mode (TCM) and Frequency Response Mode (FRM)
Line Output Configuration: One pair Single- ended via gold plated Switchcraft RCA
Single-ended output voltage and impedance: 2.1Vrms (47 Ohm)
Headphone output configuration: Single-end via 1/4" TRS Headphone Jack
HP Single- ended output voltage and impedance: 1.8V / 3V / 6.8V switchable (0.47Ohm flat in 20~20K Hz range)
THD+N: Better than 0.005%
SNR: Better than 110dB
Frequency Response: 1-50K (-3dB) control by Bessel analog filter
Power Input: 12V DC - 650mA ~ 950mA depend on system load and sampling rate
« Last Edit: 21 Sep 2015, 01:20 pm by vaprotennis »
sandbagger
Money has been sent
vaprotennis
Thanks for the purchase and will ship today!
There are still more of these GEEK PULSE units available!
eventhorizon
Interested, do you have any pictures of the actual units?
vaprotennis
Now have 3 of these DSD playing New units and slightly decreased price which is reflected in the original ad.
