OB driver reco
0 Members and 1 Guest are viewing this topic. Read 2584 times.
jhm731
OB driver reco
« on: 7 Aug 2015, 12:20 am »
Built some frames like the ones picture below a couple of years ago. Tried them with some Audio Nirvana 'Super 8 ALNICO drivers, but the results were poor.
Any recommendations for other 8" drivers to try? Add a woofer?
jparkhur
Re: OB driver reco
« Reply #1 on: 7 Aug 2015, 12:45 am »
Tang Band 1808
Dayton Audio 8 FR
Both are good and cheaper.
jparkhur
Re: OB driver reco
« Reply #2 on: 7 Aug 2015, 12:45 am »
Poultrygeist
Re: OB driver reco
« Reply #3 on: 10 Aug 2015, 11:59 am »
Wild Burro Audio Lab Betsy's. But you'll need some helper woofers.
frperdurabo
Re: OB driver reco
« Reply #4 on: 24 Nov 2015, 08:29 pm »
Helper woofer that's 10db (or more) efficient than the main driver.  This paper will explain a lot; I just built the system he describes, and bass response is excellent.
http://www.quarter-wave.com/OBs/OB_Design.pdf
ETA: you can, of course, pad the main FR driver down as much as you need - the important thing is to compensate for baffle step loss.
bladesmith
  • water quenching steel since 2001....
    • palmer knives
Re: OB driver reco
« Reply #5 on: 24 Nov 2015, 09:53 pm »
http://www.audiocircle.com/index.php?action=gallery;area=browse;image=20433
Scott F has an OB set simular to your design, I think he uses Lowthers.
They look sweet. :thumb:
Poultrygeist
Re: OB driver reco
« Reply #6 on: 25 Nov 2015, 12:54 am »
If you bi-amp it's not an issue.
