For Sale: Accessories
WTB Linn LP12 motor/pulley -50Hz (for Valhalla) , old type dustcover rest
0 Members and 1 Guest are viewing this topic. Read 1793 times.
klamka
6 Aug 2015, 08:54 pm »
Need a 50hz motor/pulley also if you have the side arm rest for the old type of linn dustcovers that would be great
Glenee
Re: WTB Linn LP12 motor/pulley -50Hz (for Valhalla) , old type dustcover rest
7 Aug 2015, 12:39 am »
I will have to check but I think I have a like new one. If I have it, it will be about a $100.00. I have alot of Linn LP12 Parts.
Glenee
Reply #2 on:
7 Aug 2015, 12:44 am »
Yep I got it. Do you want it?
Glen
Glenee
Reply #3 on:
7 Aug 2015, 12:45 am »
It is the Premotec Motor made in Holland.
klamka
Reply #4 on:
7 Aug 2015, 03:20 am »
Can't spend that much , sorry. Should have set the budget in initial post it is max- $70 .
Rgrds, K
Glenee
Reply #5 on:
7 Aug 2015, 11:35 am »
You will find a Half Life one for that. The new ones like I have are $170.00 thru suppliers.
Good Luck,
Glen
Glenee
Reply #6 on:
7 Aug 2015, 01:46 pm »
This is the exact replacement motor from Linn.
