MINT Maraschino
0 Members and 1 Guest are viewing this topic. Read 5600 times.
AmpDesigner333
  • Detailed AND Musical
    • Digital Amplifier Company
MINT Maraschino
« on: 5 Aug 2015, 10:36 pm »
This topic will have updates and information about our latest amp, the MINT Maraschino, a two-channel version of the Maraschino.
Features:
    - Selectable Front/Back inputs
    - Volume Control
    - Micro power auto-sleep mode can be turned on/off
Amplifier Stuff:
· DC coupled signal path on an isolated ground, flat down to 0 Hz !
· Low output impedance over entire audio band
· Patented and proprietary component-level design
· Two channel design is compact yet extremely powerful (up to 1000W)
Target Specifications:
    Gain: 22dB
    Sensitivity (KING 60V Version): 3.1Vin for 400Wout into 4Ω
    Sensitivity (48V Version): 2.2Vin for 200Wout into 4Ω
    SNR: 120dB
    Input Impedance: 20 kΩ, true balanced
    THD+N: 0.002%
    Frequency Response: 0 Hz to >100 kHz
    Size and Weight: 7.8" x 6.5" x 2.3", <3 lbs (amp only)
    Output Power (KING 60V Version): 400Wpc into 4Ω
    Output Power (48V Version): 250Wpc into 4Ω
    Power Efficiency: 95%
    Protection: Thermal, Current, Voltage, Auto-Recovery
    Output Impedance: <0.02Ω
    AC Power (KING 60V Version): 100-130VAC/200-250VAC, 50-60Hz
    AC Power (48V Version): 100-250VAC, 50-60Hz
    AC Power (30V Version): 100-250VAC, 50-60Hz
Thanks for taking a look.
-Tommy O
Re: MINT Maraschino
« Reply #1 on: 1 Nov 2015, 09:47 pm »
Specifications?  Reviews?  Prices?  Availability?
AmpDesigner333
Re: MINT Maraschino
« Reply #2 on: 1 Nov 2015, 10:33 pm »
Working on it.  Essentially 1000W total (both channels into 4 ohms), 120dB (target).  New boards due this week!
I'll copy some stuff over from the Kickstarter to here, but see original post for preliminary specifications....
Oh yeah, the cases will have RED panels.  Yes, it's been decided.
Thanks.
« Last Edit: 2 Nov 2015, 03:03 am by AmpDesigner333 »
OzarkTom
Re: MINT Maraschino
« Reply #3 on: 2 Nov 2015, 11:21 am »
Thanks.
That will make my buddy Rex happy. :thumb:
AmpDesigner333
New MINT Maraschino Prototype Photos
« Reply #4 on: 19 Dec 2015, 05:44 pm »
Folsom
Re: MINT Maraschino
« Reply #5 on: 19 Dec 2015, 07:29 pm »
Do you use Rush PCB? I'm a fan.
AmpDesigner333
Re: MINT Maraschino
« Reply #6 on: 21 Dec 2015, 02:52 pm »
We use a local shop for most board assembly, but did check out Rush PCB, and might do business with them in the future.  Thanks.
md92468
Re: MINT Maraschino
« Reply #7 on: 21 Dec 2015, 05:50 pm »
Any further clarity on a release date? Thanks!
AmpDesigner333
Re: MINT Maraschino
« Reply #8 on: 21 Dec 2015, 08:05 pm »
As soon as the enclosures are in, probably mid-to-end January.  Thanks.
Folsom
Re: MINT Maraschino
« Reply #9 on: 22 Dec 2015, 06:27 pm »
Ah, it just looks like their PCB board type, which is a step above in quality to many places.
AmpDesigner333
MINT Maraschino and DAC DAC
« Reply #10 on: 31 Dec 2015, 01:27 pm »
Here are a few photos of a MINT Maraschino prototype driven by a DAC DAC....
DAC DAC Kickstarter (less than 2 weeks left):
https://www.kickstarter.com/projects/378044010/dac-dac-ultra-high-performance-d-a-converter
cliffy
Re: MINT Maraschino
« Reply #11 on: 6 Feb 2016, 03:01 am »
Tommy,
How about calling the amp the "Stereoschino"
Spencer
AmpDesigner333
Re: MINT Maraschino
« Reply #12 on: 6 Feb 2016, 03:03 am »
Tommy,
Spencer
Love it!  AWESOME!  My daughter just screamed that....
