0 Members and 1 Guest are viewing this topic. Read 9215 times.
i will like to read review, impression, of some MicroZOTL owner about this amp? Perhaps also other amp by David Berning... I had no idea whait is the microZOTL sound ? thanks to all
I believe the 2 watt per channel amp, with a volume pot is available with a headphone jack. You can contact David to discuss.
good to know the microzotl is still around although i like the old lunch pail form factor better because of aesthetics.
ca you explain your experience with the Zotl and why you love it?
if someone had experience with the zotl i wish to listen to his impressions...thanks to you unknown reader
I purchased a Micro ZOTL from Mark at Urban Audio and just wanted to say it is "all of that" and then some. I can't believe how good this little one watt wonder is. I purchased it as a headphone amp but just for kicks I connected to my 93db efficient speakers and there it stays. I also own the Berning ZH230 and the Micro sounds just as good, maybe better? At least with this particular set of speakers.
