Bryston Phono stage
0 Members and 1 Guest are viewing this topic. Read 1015 times.
sweetspot
Bryston Phono stage
« on: 3 Aug 2015, 02:40 pm »
I currently own a BP-25 preamp with built in MM phono stage.Was wondering what the difference is between the built in phono stage & the BP1.5. Is this an upgrade worth considering?
  • The Demo is Everything!
    • http://www.bryston.com
Re: Bryston Phono stage
« Reply #1 on: 3 Aug 2015, 03:02 pm »
Hi
The same phono stage in both except the BP1.5 has both MM and MC sections - which you can install in the BP-26 as well.
james
sweetspot
« Reply #2 on: 3 Aug 2015, 03:29 pm »
Thanks,James
