SOLD: Luxman L-505uX Integrated Amp
0 Members and 1 Guest are viewing this topic. Read 4734 times.
christopher3393
« on: 2 Aug 2015, 07:39 pm »
SOLDLuxman's staple integrated amplifier, full sized, fully functioned. Class AB – 100 watts per channel, discrete volume control. Purchased 9/2014 from authorized dealer. Used only at low or medium volumes. Excellent condition. Shipping to continental U.S. included in price. Verified Paypal only. I'll absorb the Paypal fees. Includes power cord, remote control, manual. Original double-boxed packaging. Ships from 53711, Madison, WI. I use the same name for Ebay and have sold several items here and on CA with no problems.
Retails for $4,000.00
Asking $2,200.00 This is a low price for this unit in this condition.
Link to info: http://onahighernote.com/shop/integrated-amps/l-505ux/
« Last Edit: 17 Aug 2015, 07:40 pm by christopher3393 »
christopher3393
Re: FS: Luxman L-505uX Integrated Amp
« Reply #1 on: 4 Aug 2015, 11:23 am »
Price reduced to $2,400.00 This includes shipping.
christopher3393
« Reply #2 on: 11 Aug 2015, 11:44 am »
Price drop to $2,200
keihin
« Reply #3 on: 14 Aug 2015, 06:43 pm »
I have questions about the L-505uX's preamp outputs. In normal operation, are these active and available for use in feeding a powered sub-woofer?
I know this model has an operational mode that lets you use it as a preamp-only (feeding an external power amp), and power-amp only (fed by an external preamp).  This made me wonder whether the preamp output was energized when not in one of these special modes.
I was also wondering whether the preamp output might always be energized, but with it's output signal required to feed the main input jacks.  I own a pair of Luxman R-115 and R-117 receivers, and on these models the preamp outputs and main inputs are connected by external RCA interconnect jumpers.  On these, there is no internal connection from preamp to power amp and removing these jumpers will remove the input signal from the power amp, effectively disabling its operation.
I'm considering the L-505uX model to replace my R-115, which is in a system that employs bookshelf speakers (with limited low-end extension) and a powered sub.  Given this, I need to know that I can retrieve a variable-volume preamp output from the L-505uX while still using its internal power amp.
Thanks in advance for any reply.
christopher3393
« Reply #4 on: 15 Aug 2015, 12:18 pm »
My apologies, keihin. I do not know the answer. The manual does not seem to be available online and mine has been packed (double-boxed) with the amp.
srb
« Reply #5 on: 15 Aug 2015, 01:45 pm »
Can't verify the accuracy of the statement, but in a FAQ from vendor On a Higher Note :
Q: "Are the pre outs on the L-505uX always hot or do they only turn on when the separate function is engaged? The reason I’m asking is I have a prospective client who is interested in the L-505uX and wants to use his subwoofer with it. If the output is not always active, I assume I can split the signal with a Y adapter and send the signal to both the sub and the main in."
A: "The PRE out is always hot."
RDavidson
« Reply #6 on: 15 Aug 2015, 02:29 pm »
The manual can be found online.
Yes, the preout is always active.
christopher3393
« Reply #7 on: 15 Aug 2015, 07:36 pm »
Thanks srb and RDavidson.
christopher3393
Re: SOLD: Luxman L-505uX Integrated Amp
« Reply #8 on: 17 Aug 2015, 07:40 pm »
SOLD
