Using REC out to drive power amp
0 Members and 1 Guest are viewing this topic. Read 4875 times.
G E
« on: 31 Jul 2015, 05:15 am »
Hello,
A friend of mine has a JVC receiver of fairly recent vintage and needs to be able to drive an AVA Omega 3 power amp. There are no pre outs but he does have two REC outs.
I know the best course is to replace the receiver with a preamp but he is retired and is working on a limited budget.
Is it possible to take a signal from the REC out and through a potentiometer which becomes his volume control?  If so, what value pot should be used and how should this be wired?
I have a stand alone headphone amp but if this is used to drive the amp will therebe an impedance mismatch with its output and the omega 3 input?
Also, if no speakers are attached to the receiver speaker terminals is there a risk of damaging the associated circuits?
Thanks for your ideas.
Greg
Wayner
Re: Using REC out to drive power amp
« Reply #1 on: 31 Jul 2015, 08:31 am »
Can't use the record outs because they are not in the volume control circuit and therefore, would not have any volume "control".
This just is a really bad idea. And you are right, he needs to get a preamp.
Frank does get used preamps from time to time.....http://www.avahifi.com/index.php?option=com_content&view=article&id=125&Itemid=176
Although, this device might work with the record out or better yet, between the source (like a CD player) and the amp: https://emotiva.com/products/electronics/control-freak
Wayner
dflee
« Reply #2 on: 31 Jul 2015, 02:14 pm »
I had some old receivers that had bridge pins between the pre stage and amp stage.
Remove the pins and you could use the unit for either pre or amp.
Don
G E
« Reply #3 on: 1 Aug 2015, 12:03 am »
Don
No bridge pins or connectors on this.
dflee
« Reply #4 on: 1 Aug 2015, 12:50 am »
Possibly a volume control of some kind between the two then.
modular747
« Reply #5 on: 1 Aug 2015, 09:15 pm »
You mean like when he said:  "Is it possible to take a signal from the REC out and through a potentiometer which becomes his volume control?"
