USB Cable for Lampi Owners
0 Members and 1 Guest are viewing this topic. Read 6515 times.
morganc
« on: 26 Jul 2015, 08:55 pm »
Hey guys,
   I have a new Lite 7 with VC ( the Newport Beach Show special) and I am taking a survey to begin my USB cable search.  I am only asking Lampi owners what there favorites are in their system as I want to know from those more experienced than I what there final choice/choices was for this cable.  I have a generic USB cable now.  Of course, I know this is system dependent, and the usual disclaimer, so no need for someone to come on here and educate me on that, just looking for some ideas and light discussion.
Thanks in advance,
Morgan
morganc
Re: USB Cable for Lampi Owners
« Reply #1 on: 26 Jul 2015, 08:56 pm »
And for clarification/insight my system consists of :
GR Research Super V's
Joule Electra Monoblocks
Lampizator Lite 7 with VC with EML 45's.
Auralic Aries Streamer
Tomy2Tone
« Reply #2 on: 26 Jul 2015, 09:07 pm »
Congrats on the Lite 7!
My choice of USB cables would be the TotalDac D1. It's everything you want in a cable. Neutral, transparent, musical....
I've tried the Revelation Audio Labs dual conduit and although it's good it didn't compare to the TotalDac. The D1 is pricey at about $440 including shipping from France depending on the exchange rate but it's really a cable you can get and never search again.
sfox7076
« Reply #3 on: 27 Jul 2015, 01:02 pm »
Run to the accessories board and by the used Danacable for sale.  It has killed any cable in my system, with or without the Uptone Regen.  It's pretty amazing.
morganc
« Reply #4 on: 27 Jul 2015, 05:33 pm »
Thanks for the heads up on the DanaCable but I just missed it.
guf
« Reply #5 on: 27 Jul 2015, 10:59 pm »
I'm happy with the mapleshade i've been using i think its only 150$. I'd even let you borrow it for the weekend if you wanted. I also use the Regen.
morganc
« Reply #6 on: 28 Jul 2015, 03:50 am »
Thanks Guf.  I would love to hear both the Mapleshade and the regen.  Are you using the two together?
morganc
« Reply #7 on: 28 Jul 2015, 05:12 am »
What cables are you guys using with the USB Regen?
guf
« Reply #8 on: 28 Jul 2015, 03:36 pm »
yup, I used the Mapleshade before I got the Regen but using them both together. Happy to let you use both. I have a few Phishing trips planned soon :) Happy to let you try out while I'm gone.  Message  me.
« Last Edit: 28 Jul 2015, 08:58 pm by guf »
doak
« Reply #9 on: 29 Jul 2015, 03:34 am »
Nice system.  Woof!!!   :thumb:
wisnon
« Reply #10 on: 29 Jul 2015, 08:49 pm »
Corning Optical with Regen, TotalDac usb cable, iFi Mercury Cable, Light Harmonic cable, etc..
JM21
« Reply #11 on: 4 Aug 2015, 05:13 pm »
Greetings,
I have a Lampi L4G4 w/ Duelands & VC.  I had settled on the Wireworld Platnum as my reference. It was a very good/natural sounding cable (I believe mine is ver 6...up to 7 currently).  Late '14 I went to the Light Harmonic LightSpeed, split version. It uses a separate 'leg' for the power.  It's a little pricey but in my system it outperformed the WP noticeably. LH provides some good info on their website regarding their thought process behind the design.    Wireworld I believe separates their power line inside the molded cable which may be part of their success/performance.
Good luck with your search!
JM
wisnon
« Reply #12 on: 5 Aug 2015, 08:30 am »
Corning Optical USB...but I have the GREEN original regen...Have not put in the Amber board yet, as I just got my $53 Chinese LPSU yesterday.
ddark65
« Reply #13 on: 17 Sep 2015, 01:20 am »
I heard the Nordust USB cable is suppose to ne real good
jtwrace
    • TIPP YouTube Channel
« Reply #14 on: 17 Sep 2015, 01:21 am »
Just buy the ZatorKable!
doak
« Reply #15 on: 17 Sep 2015, 03:15 am »
Now you've done it.
"ZatorKable" is already trending on Google.   :lol:
jcbbytes
« Reply #16 on: 5 Oct 2015, 08:19 pm »
Anyone compare the Dana usb to the Verastarr usb ?
I know that the Dana was used in the past at shows with the Lampi but the Verastarr was used at RMAF
A PM would be fine ,instead of a post,if concerned about "stepping on toes"
sfox7076
« Reply #17 on: 5 Oct 2015, 11:17 pm »
IMO, I am not sure how you compare given the different systems involved.
