Please help me set up a dedicated 5khz network for streamer
0 Members and 1 Guest are viewing this topic. Read 1109 times.
santacore
Hello all,
I'm hoping someone can help me maximize my setup. I currently have a new Apple Airport Extreme, Synology NAS (with my music library), and an Auralic Aries streamer. It's my understanding that I should have a dedicated 5khz network (?) for my steamer to maximize streaming. I'm Apple literate, but don't have any IT background. Can anyone give me basic instructions or direct me to a link that might help me set this up. Thanks!
srb
Re: Please help me set up a dedicated 5khz network for streamer
« Reply #1 on: 24 Jul 2015, 08:41 pm »
I assume you mean 5GHz network.  Your Airport Extreme is a dual band router that has two wireless radio networks, a 2.4GHz WiFi network and a 5GHz WiFi network.  To have the 5GHz network "dedicated", you will want to restrict access to just the Aires streamer.
I believe by default the 2.4GHz and 5GHz will share a single WiFi network name (SSID).  In the Airport Utility application under the Airport > Wireless tab you will name the (2.4GHz) network, then you can click the Wireless Options button at the bottom to give the 5GHz network a different name.  This will prevent devices from automatically choosing one or the other.
To prevent other devices from inadvertently connecting to the 5GHz network, you can use MAC address filtering under Airport Utility > Airport > Access tab and enter the Aires hardware MAC address.
Note that MAC address filtering and even hiding the SSID are not meaningful security measures, as a hidden SSID can be easily found and a MAC address can be spoofed, but they will prevent your family and friends from intruding on your "dedicated" 5GHz network.
Your WPA2 security passphrase is really the only security measure against hackers.
Also note that although the 5GHz band generally has less interference, it also has a shorter range than the 2.4GHz network, so your distance, type and number of walls, etc. will determine if the 5GHz band will work well in your particular installation.
santacore
« Reply #2 on: 24 Jul 2015, 08:48 pm »
Fantastic information, thank you so much Steve for taking the time to explain!!!! I will dig into the Airport settings this weekend. Luckily my system is the in the same room, so I shouldn't have any distance issues.
John
