Which 6SN7 tube for my Wyetech Topaz amp?
0 Members and 1 Guest are viewing this topic. Read 1644 times.
bebop86
« on: 24 Jul 2015, 12:06 pm »
Guys - Which is the best 6sn7 to use in my topaz SET amp- I am using the GE 211 tubes and the Wyetech Ruby pre- any thought of which tube and where to get the "real" version is much appreciated- Gary
« Last Edit: 25 Jul 2015, 10:14 am by bebop86 »
DaveC113
  • ZenWaveAudio.com
Re: Which ^SN& tube for my Wyetech Topaz amp?
« Reply #1 on: 24 Jul 2015, 04:16 pm »
IME there are no bad 6SN7s, the hyped/expensive ones may be a tiny bit better in some gear but they aren't worth the price imo.... My favorite tube is probably the 5692, I have RCA and Sylvania and they are the exact same tube but the Sylvanias are right at or just under $100/pair and the RCA red base are closer to $150/pair. These tubes have a reinforced internal structure and are very quiet. Otherwise just about any Sylvania sounds very good to me, the Russian variants are fine but be careful as there are a lot of different ones. The 1578 with black hole-plates are the grail but nearly $200/pair. People try to sell any metal-base 6N8S for big $ though, only the one I mentioned is worth more than $100/pair. Some people think the newer coin-base tubes are not as good but ime they are very good, better than most early production 6SN7 and you can get them dirt cheap.
I rotate tubes but right now I have metal base 6N8S with black plates as voltage amps and coin-base no-name tubes as output tubes in my preamp....
RPM123
« Reply #2 on: 24 Jul 2015, 04:28 pm »
Not familiar with your amp, however, you may find something worthwhile in the link below re: various  6SN7 tube characteristics.
http://www.head-fi.org/t/117677/the-reference-6sn7-thread
« Reply #3 on: 25 Jul 2015, 01:01 am »
6SN7 RCA black plate is always good.
