0 Members and 1 Guest are viewing this topic. Read 6395 times.
Diffusion needs a minimum distance between the treatment and the listener, for it to work optimally. So having 10' ceilings, you may be OK, depending on what you use, and the distance you have. I use absorption on my 8' ceilings, as the panels are only 4' - 5' from my ears. Using 1d QRDs on the front wall, as they are 10' away from the chair. Some folks will argue that a small room will show little benefit with diffusion, but I noticed an improvement with the QRDs in mine. On the other hand, placing poly diffusers at the side wall reflect points, which worked great with my old Maggies, was too much (think the term is ringing?) with the present KEF speakers.
...The point is you want to hear, within the first 20ms only what is coming out of the speakers. Not the speakers plus the 0-20ms reflection from the sidewalls/ceiling. In that first 20ms, the brain cannot separate the reflection from the direct sound so it translates it to sound like smearing. ... Glenn,GIK Acousticsplus one!
