Capital Audiofest
0 Members and 1 Guest are viewing this topic. Read 2312 times.
craigh
Capital Audiofest
« on: 22 Jul 2015, 03:38 am »
Are you going to be at the Capital Audiofest this year?  I'm looking to listen to preamps to go along with my Khartago.
Hadro
Re: Capital Audiofest
« Reply #1 on: 26 Jul 2015, 08:29 pm »
Get a Candela and save yourself time.
craigh
« Reply #2 on: 27 Jul 2015, 04:18 pm »
I'm leaning towards that but I really want a tape monitor.
LateApex
« Reply #3 on: 28 Jul 2015, 09:47 pm »
Pretty sure Klaus can build you one with a tape monitor.
I am very happy with my Candela - just now starting to explore tube rolling, which is a whole new angle to have fun with.  With that said, it sounds great stock, should you not be into rolling.
Phil A
« Reply #4 on: 28 Jul 2015, 10:18 pm »
+1 - actually got mine at the 2013 CAF
erniek
« Reply #5 on: 29 Jul 2015, 07:01 pm »
What tubes would you recommend as a next step up in sound quality for the Candela?
AlTran
« Reply #6 on: 30 Jul 2015, 10:24 pm »
You can't go wrong with either Amperex 7316 or Psvane MK II.
