SOLD - Gustard U12 - USB to SPDIF - price lowered to $125
0 Members and 1 Guest are viewing this topic. Read 1077 times.
akai
I have two units and only use one, this one (black) is about a week in use.
GUSTARD U12 32Bit / 384KHz DSD XMOS USB Digital Audio Interface
Description
 Gustard U12 digital interface XMOS program complete independent linear power interface 0.1PPM crystal support 32B 384K
 U12 uses the company used in professional audio field XMOS latest chip U8, inside there are eight cores, with powerful multi-core multi-thread processing capability, is the industry's very good USB Audio Class 2.0 digital audio solutions.
 Features:
 Increase the screen display, the sampling rate at a glance
 Use XMOS programs to support 32B 384khz asynchronous 2.0 (USB recommended that ASIO output)
 Using an independent power supply. Built-in sealing ring cattle, multiple sets of multi-level regulation. About the importance of independent power, I believe we all know.
 Optimize the design of the audio clock circuit using 0.1PPM precision active crystal to provide a more perfect clock signal to digital audio. Provided for by the two crystals were 44.1 / 88.2 / 176.4 / 352.8Khz and 48/96/192 / 384Khz series rate signal only after the selected clock rate selected work, work another one audio clock stop, put an end to the mutual interference may bring work simultaneously when the two clocks.
 A total of four kinds of output: Coaxial (RCA), optical fiber, AES / EBU, IIS (HDMI port)
 Coaxial fiber AES / EBU output formats IEC60958 and AES3-r2009 standard limits the maximum support 24Bit / 192kHz; IIS can transmit 32B 384K
 Smart switch, USB has a current interface to boot. Interface with the computer switch and switch machine (computer to be set off USB power failure), or unplug the USB cable directly to the shutdown.
Technical Parameters:
 Laser marking, never fade
 Built-in smart switch, plug in USB automatically
 Two 0.1PPM precision crystal 45.1584M 49.1520M
 International voltage AC115V-230V, the need to manually adjust
 Rigorous design, reasonable layout, elegant lines, solid materials.
 Figures show that a mesh understand. DSD support 128, PCM supports 384K
 Aluminum chassis, the drawing process, the body all black, black and silver optional panel
 XMOS - U8 chip, support 32BIT / 500MIPS digital signal processing unit, the inside has eight cores.
 Interface from left to right are: power input AES / EBU output coaxial output IIS output optical output USB input
Machine size (not including protruding parts): Width 160mm × 50mm × depth 120mm high
Package Size: Width 225mm * 80mm * Deep 190mm high
Weight: Net Weight 1KG, including packaging 1.3KG
Price is $125 shipped (Paypal verified address only).
« Last Edit: 23 Jul 2015, 10:27 pm by akai »
akai
Re: Gustard U12 - USB to SPDIF - price lowered to $125
« Reply #1 on: 23 Jul 2015, 01:43 am »
Bump
Flac2Dac
« Reply #2 on: 23 Jul 2015, 09:53 pm »
PM sent.
