Where's the music
0 Members and 1 Guest are viewing this topic. Read 2758 times.
drummermitchell
Where's the music
« on: 15 Jul 2015, 10:09 pm »
This is disappointing  as just had the new card installed in the BDP-2 in the city.
Hooked her  all up and F'all. :o.
All we get on the player is MPD ready :scratch:,
on the my computer it says NO AUDIO DEVICE FOUND
checked the cables ect and rechecked all is good
Dac is getting it's signal ect
Anyone know whats going on.
  • The Demo is Everything!
    • http://www.bryston.com
Re: Where the music
« Reply #1 on: 15 Jul 2015, 10:14 pm »
Hi Don
Go into Audio Devices - bottom of the page on Manic Moose Dashboard and click on the sound card - it will probably be in RED showing it is not being seen by your DAC
james
drummermitchell
Re: Where the music
« Reply #2 on: 15 Jul 2015, 10:41 pm »
Hi James,
went there and it says...audio device ready so I clicked apply still nothing
Wonder when the card was installed something perhaps not connected or...................
Audio devices are all blue ,nothing in red.
Re: Where the music
« Reply #3 on: 15 Jul 2015, 10:48 pm »
Hi James,
OK just try shutting it down and restarting.  Did they test it at the store?
We can have Chris look at it if you put it in service mode.
I will forward this to Chris,
james
drummermitchell
Re: Where's the music
« Reply #4 on: 15 Jul 2015, 11:08 pm »
tried that...same thing.
the shop has no wifi or hard connectin.
Bob tried it in  a show room which had a BDP-1 and all it said was MPD ready.
Their wifi couldn't see the BDP-2 :scratch:
THX for James,Chris,Bob(Audioark) for getting back,
I'll sit on my 4'x3' cement pad and have a few more 4 degree Kokanee and not get excited about the no sounds of music.
Will Call Chris in the AM,he likes that :thumb:
unincognito
    • bryston.com
« Reply #5 on: 16 Jul 2015, 12:15 am »
The button next to the the Bryston audio device, does it say enable or disable?
If you can view or download the new BDP intro video posted yesturday, one of the very first things covered is the audio devices page
drummermitchell
« Reply #6 on: 16 Jul 2015, 12:22 am »
Hi chris,hit audio devices.....doesn't say anything like that
will add when I first go on the BDP manic moose it says...my ip address doesn't appear to be responding
it is the same on the BDP though
BrysTony
« Reply #7 on: 16 Jul 2015, 01:22 am »
Sounds like your network may not be recognizing the new BDP configuration, i.e., no basic security handshake.
Tony
drummermitchell
« Reply #8 on: 16 Jul 2015, 03:49 pm »
Looks like I'm off to Edmonton to ship back to Bryston.
Chris had me shoot some picts of the install and all looked good.
Looking at ithe picts on the instructions everything lines up..............................soooooo oooooooooooooo
Chris came on remotely and can't access I believe, so it may be the cabling that came with the card or sound card or whatever.
She worked great before,just a little venting ARRGH.
drummermitchell
« Reply #9 on: 23 Jul 2015, 02:58 pm »
Just got off the ph with mike.
My BDP-2 is on  final check out :thumb:.
I guess one of the cables was installed wrong as there are two connector inserts and was inserted in the wrong one.
Guess it was pretty hard to see.
So all's good cept for my down time,at least it was just an error not a defect :thumb:.
