Tweeters for Fostex FE168EZ or Hemp 6.5 in BLH?
0 Members and 1 Guest are viewing this topic. Read 2177 times.
KnyazHM
« on: 14 Jul 2015, 09:51 am »
I want to try tweeters for my back-loaded horns on Fostex FE168EZ. Now I use in this enclosure Hemp drivers, similar to these, but the basket as the Omega 6.5 drivers
www.tempomusic.hu/pdfek/fr65c.pdf
What tweeters a try? Fostex T90A, T900A, T925A, T500A? May be JBL 2405?
Any recommendations?
Thank you
Scottmoose
Re: Tweeters for Fostex FE168EZ or Hemp 6.5 in BLH?
« Reply #1 on: 15 Jul 2015, 01:09 am »
Leaving aside the fact that the Fostex FE168Esigma back-horn is something of a mismatch with the hemp drivers mentioned, according to their specs. at least (to each their own & all that), it really depends how much you want to spend, and the nature of the crossover you're planning on.
What I can say is that I like the T900a; it's an excellent performer, but comes a rather hefty price. The T90a is also quite good -not as good as the T900a, but being a cheaper model, you wouldn't expect it to be. At slightly less rarefied levels, you might want to look at the gold-dome Audax, or some of the pro-audio units available.
yeldarb
« Reply #2 on: 15 Jul 2015, 04:10 am »
You might contact Madisound and ask about the Fostex supertweeters and crossover that they used to use on the BK16.  Or tell them what you are using and ask for a recommendation.
