BDP-2 and BubbleUPNP Server: No Signal when using SPDIF
0 Members and 1 Guest are viewing this topic. Read 1998 times.
cmarinsr
Hello,
I'm new to this forum so, please, bare with me...
I'm trying to use the BDP-2 as an OpenHome renderer in conjunction with BubbleUPNP server and the Lumin App as a controller. Works nicely when using the USB output  (BDP-2 -> Audiophilleo 2+ PurePower -> Naim Dac) but I get no digital signal when using SPDIF (BDP-2 -> Naim Dac). Both outputs work when using MPD.
Can somebody tell me what am I doing wrong?
unincognito
    • bryston.com
Re: BDP-2 and BubbleUPNP Server: No Signal when using SPDIF
« Reply #1 on: 14 Jul 2015, 11:50 am »
you get one or the other, if a USB DAC is plugged in during startup the USB DAC will take priority over the SPDIF.
cmarinsr
« Reply #2 on: 14 Jul 2015, 01:10 pm »
Thank you! I will disconnect the USB cable, restart the unit and see what happens.
cmarinsr
« Reply #3 on: 14 Jul 2015, 02:16 pm »
Thanks again, Unincognito, worked like a charm! Now, how can I make Tidal to work? I'm on the latest stable (non-beta) firmware.
unincognito
    • bryston.com
« Reply #4 on: 15 Jul 2015, 12:54 am »
Could you be a bit more descriptive? Does it not play?
cmarinsr
« Reply #5 on: 15 Jul 2015, 01:39 am »
No, it doesn't from the MM web ui (I'm able to login, I can access My Music, I can start playing, but no signal is passed to the Dac).
unincognito
    • bryston.com
« Reply #6 on: 15 Jul 2015, 02:48 am »
you should check the output device in setting
cmarinsr
« Reply #7 on: 15 Jul 2015, 03:42 am »
My settings are
Lossless
Mod
ESI Juli@ - ICE1724,0'p
I am unable to change the settings. When pressing Apply, the text becomes blue but nothing happens (new values are not displayed)
unincognito
    • bryston.com
« Reply #8 on: 15 Jul 2015, 04:56 pm »
My settings are
Lossless
Mod
well that's the analog section you have selected, choose the other output, click apply
cmarinsr
« Reply #9 on: 15 Jul 2015, 05:45 pm »
Well, as I was mentioning before, I've tried changing that several times and clicked on Apply to no avail. Apply becomes blue and stays this way until I refresh the page but the selection does not change. Can this be generated by the fact that I recently got the player from one of my friends and he was using Tidal with different credentials? Is there any cleanup to be done before changing the user in Tidal?
unincognito
    • bryston.com
« Reply #10 on: 15 Jul 2015, 06:17 pm »
then place the bdp into service mode and email me the service id
cmarinsr
« Reply #11 on: 15 Jul 2015, 06:47 pm »
Thanks a lot! I'll do this, tonight, when I'll get home.
