0 Members and 1 Guest are viewing this topic. Read 5191 times.
Player software with built-in EQ is actually less complicated than the baffle step
In case you haven't noticed the age of the physical disk is all but over, so why invest in a nice CDP?
jarcher:Thanks for the plug for JRiver. Is it super easy to install/use?I agree that the Aires type pieces will be the future of higher-end audio sources. But for now I don't need to invest in another box, just an affordable/easy to use player software.
