Anyone out there ever use Eighth Nerve stuff??
0 Members and 1 Guest are viewing this topic. Read 2998 times.
maxwalrath
« on: 7 Oct 2004, 02:50 am »
I got my eighth nerve response stuff today and was about to put them up. I remember reading a while ago about how exactly to hang them, but I can't find the post.
The instructions make it sound like you want to keep the corners flush to the walls, but I think I remember reading that there should be some space left clear between the wall and the product. Could anyone out there who has response products in their rooms tell me the right way?
Max
maxwalrath
« Reply #1 on: 7 Oct 2004, 11:25 pm »
bump...
PhilNYC
« Reply #2 on: 7 Oct 2004, 11:32 pm »
max,
the Response products should be placed diagonally across the intersection of the walls, forming a triangular space with the stiff/reflective side facing into the room.
WilliamL
« Reply #3 on: 7 Oct 2004, 11:43 pm »
Yes Max,
Leave some space behind the corners and make sure they straddle both side walls.
If you are having problems give us a call....
Best,
Bill Laurent
satfrat
« Reply #4 on: 8 Oct 2004, 06:40 am »
Max, check out this site for detailed pictures on installation ideas. :D  http://www.soundscapehifi.com/en.htm     Regards, Robin
