0 Members and 1 Guest are viewing this topic. Read 2802 times.
... one thing I should have mentioned is he would like to use his ipad/iPhone for the volume as well because he wants to be able to walk around and control the music and volume without having to have a remote.
Try Radio Paradise. Not high rez, by any definition, but decent and the play list is awfully good, to me, anyway.
We are also setting up a two channel system but he will probably use a laptop with a separate hard drive and dac for that and I'm a lot more familiar with what it takes to make that sound good.
Depending on where he will be walking around, a WiFi solution with its inherently far greater range may be preferable to the much shorter limited ~ 30 ft. range of Bluetooth.Steve
Some more thoughts...Many music apps have a volume control built into the app. So feeding directly into an amp using a bluetooth adapter shouldn't create a problem. The manufacturers are beginning to come out with stereo receivers that support Bluetooth and Wifi. They come with an app to control the receiver via phone or tablet. The new Onkyo 8160 is one example. You can download the app to see what features are provided by the app.Since he is using Apple products I think you could use and an Airplay adapter of some sort. I am not familiar with Airplay. It might be a simple as an Airport Express connected to the Crown amp. There are many compatible airplay receivers out there too.
Maybe just a newer run of the mill receiver with build in wifi
That is not sufficient. WiFi is the transport layer. You also need a common protocolAs it is a iPhone, look for Airplay support.If both phone and receiver support WiFi Direct you don't need a LANhttp://www.techradar.com/news/phone-and-communications/mobile-phones/wi-fi-direct-what-it-is-and-why-you-should-care-1065449If one of them don't you need a router.Not to make an internet connection but because you need a box creating the LAN (DHCP, etc)
