Cable Gauge limit for remote triggers
0 Members and 1 Guest are viewing this topic. Read 2384 times.
Rod_S
« on: 8 Jul 2015, 02:51 pm »
Hi;
I'm curious what the max cable gauge limit is for the triggers on the amps and has it actually changed over the years and/or does it actually vary based on model? The reason I ask is looking through the various manuals I'm seeing different gauges mentioned so I don't know if that's really true or just inconsistency in the manuals.
I'm going to need longer runs when I split my 28's apart later this summer and my dealer gave me a 50' run of speaker wire to help me figure out how long my new interconnects need to be but aside from that I didn't think I had any use for the wire. But... if this 16 gauge wire will work for the triggers I'll simply use that. I don't feel like getting down behind everything at the moment and disconnect my current wires to see if this will work. Yeah, Yeah, I'm lazy. plus I hate those freakin' screw based trigger connectors :) Why oh why couldn't all of the triggers on all Bryston components have been the little mini jacks :(
Rod
srb
Re: Cable Gauge limit for remote triggers
« Reply #1 on: 8 Jul 2015, 03:23 pm »
The gauge of a typical 1/8"/3.5mm mini phone plug cable is probably in the 24 - 28 awg range.  There isn't a standard current spec for 12V trigger relays, but I suspect most are well under 100mA.
I think your 16 awg wire would be adequate for most any situation, as 16 awg wire with 12VDC and 100mA current will only have a voltage drop of 3.33% or .4V drop over 500 ft. !
Rod_S
« Reply #2 on: 8 Jul 2015, 04:26 pm »
hmm, I never even thought of it from that perspective so that's good info, thanks. I was just simply thinking are the wires going to be too thick to fit into the slots :)
srb
« Reply #3 on: 8 Jul 2015, 04:43 pm »
Oh.  :oops:   Well that is a good question as the currently posted 28BSST² manual on the Bryston website says 18 - 22 "gage".  Conservative or absolute?  I'm hoping the next larger 16 gauge will fit, although I wouldn't expect 14 gauge to fit.  Looks like you might have to get down behind the amps and give it a try.
Of course if it doesn't you could always bastardize the wire by simply removing a few strands to reduce it down to 18 gauge.
Rod_S
« Reply #4 on: 10 Jul 2015, 06:04 pm »
Yeah I suppose I could cut away some of the wire.
I just checked my actual manuals and for all my amps, the 4B-SST, 6B-SST and 28-SST2s they all list only up to 18 AWG. Checking the 7B-SST2, 4B-SST2/3B-SST2, 6B-SST2 manuals on-line it states way up to 12AWG. The 9B-SST2, 28B-SST2 and 14B-SST2 manuals on-line list just up to 18 AWG.
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #5 on: 10 Jul 2015, 06:05 pm »
Hi
You can use really thin gauge as you are only turning on a switch.
james
Rod_S
« Reply #6 on: 10 Jul 2015, 07:52 pm »
Thanks James but my concern is how thick is the actual limit as I have a bunch of 16 AWG speaker wire I got for free and if that works I'll definitely use it. Aside from potentially trigger wire this type of wire is only really as good as a garbage bag tie :)
« Reply #7 on: 10 Jul 2015, 09:34 pm »
No harm in using thick gauge
