0 Members and 1 Guest are viewing this topic. Read 7418 times.
MTM (D'Applito) vertical arrangement helps eliminate floor and ceiling reflections (helping to comply with THX movie standards), but to avoid phasing issues between the midrange drivers the listener must sit exactly equal distance from both drivers (this is why MTM doesn't work in horizontal arrangement for center channel use). MTM also allows for greater overall speaker efficiency as tweeters are typically more efficient than mid/woofers. A seldom thought of issue is the sound that backwaves inside the cabinet produce. Delayed/out of phase sound come out ports. The same is true for any cone (drivers or passive radiators) as their thin/lightweight materials allow much more sound to be transmitted through (like heat going through a window versus an insulated wall). Having additional drivers is provides more delayed/out of phase sound to come out.Another seldom thought of issue regarding backwaves is how a sound waves inside a box, especially those with a hole behave. If you rounded the box and made it smaller you'd have a flute. Where you blow changes the sound. If you could blow into two holes at once it'd sound different, as it must in a floor-standing MTM.Knowledgable listeners look for at least 6 inch drivers to fully support mid/bass frequencies that add solidity/body to reproduced music. The argument of spending "X dollars" on one better driver or multiple poorer ones comes to mind.Single order crossovers provide superior imaging for TM design (look at Fritz Speakers for examples).
