4-6 outlet power bar
0 Members and 1 Guest are viewing this topic. Read 4482 times.
oskar
« on: 25 Jun 2015, 03:55 pm »
I'm running out of receptacles. Please suggest a reasonable $100.+- power bar for Dac, CdP etc.
ACHiPo
Re: 4-6 outlet power bar
« Reply #1 on: 25 Jun 2015, 08:24 pm »
Have you thought about making one?  I made one using Hubbell quad hospital grade outlet and silver-plated Teflon insulated wires braided into a Hubbell hospital-grade plug.  I bought the outlet on EBay for about $10, the wire and plug were another ~$60.
Larkston Zinaspic
« Reply #2 on: 25 Jun 2015, 10:09 pm »
I think the Wiremold L10320 is very good. I'm still using one.
Doublej
« Reply #3 on: 26 Jun 2015, 12:04 am »
I too use the Wiremold.
Emotiva, Signal Cable and Wireworld have products just north of $100.
You could also consider a hospital grade power strip from Tripp Lite or other manufacturer.
oskar
« Reply #4 on: 26 Jun 2015, 04:11 am »
Thanks APHiPo Interesting idea but not into diy on this one.
all I want at this price level is something that doesn't screw with the sound.
Tripp lite I have heard of and will look into Wire world.
Sometimes ì think that stuff not audiophile approved is the best value  .
ACHiPo
« Reply #5 on: 26 Jun 2015, 12:54 pm »
In that case go the hospital-grade route
Wiremold 6 Outlet
Tripp Lite
riffer
« Reply #6 on: 26 Jun 2015, 01:06 pm »
PS Audio Juice Bar or Juice Bar 2.
Unfortunately, not a currently manufactured item, so you will have to find one used.
Wayner
oskar
« Reply #9 on: 27 Jun 2015, 05:08 pm »
Ok thanks for the suggestions.
I'm ordering the tripp lite from amazon.
toddc2
  • That dog sure loves beer
« Reply #10 on: 14 Jul 2015, 07:14 pm »
+1 on the Juice Bar 2
I picked up one of these about a year ago used for $150, I think it has that much is outlet parts costs alone. Great value!
rlee8394
« Reply #11 on: 14 Jul 2015, 09:26 pm »
This works very well, and is built like a tank. Can't beat it for the price and much better than standard surge strips.
http://www.monoprice.com/Product?c_id=109&cp_id=10912&cs_id=1091201&p_id=9290&seq=1&format=2
-Ron
