0 Members and 1 Guest are viewing this topic. Read 8540 times.
Check out the Bottlehead amps (2A3 and 300b)...they are amazingly well designed amps. John
I would suggest the Decware 34SE, with 6W and a sole EL34 tube, you can choose the 6N1P or 6N2P input tube.The EL34 tube is know as a very musical(warm) tube which turns bad recorded CDs in good ones.And its not expensive as the 300B.
