Planar mid for computer speakers?
0 Members and 1 Guest are viewing this topic. Read 1549 times.
PMAT
« on: 18 Jun 2015, 06:14 pm »
just a thought, I would like to have better music at work but space is very limited on my desk. how could you implement the planar mids as full range (limited) computer speakers?
HAL
Re: Planar mid for computer speakers?
« Reply #1 on: 18 Jun 2015, 07:16 pm »
Take a look at Monsoon computer speakers.  No longer made, but still on eBay.
They use an earlier version of the planar driver.
Stimpy
« Reply #2 on: 19 Jun 2015, 12:13 am »
I own several sets of Monsoon's different PC speakers, and all are very good.  Not a VMPS, but pretty good, just the same.
There are 3 main models to look for: the MM-1000s, MM-700s, & MM-702s, in chronological order.  There was also a 4 panel surround set, the MM-2000s.  Monsoon had other smaller or later 2.1 systems, but none sounded as good as these earlier versions.
Eminent Technology had a higher end set of 2.1 PC speakers as well.  They were LFT-11s.  These had mid/treble panels, mated to a 'sub' with dual 6.5" woofers.  Much rarer than the Monsoons, and much more expensive, at about $650 retail, IIRC.  No longer produced by Eminent.
PMAT
« Reply #3 on: 19 Jun 2015, 05:03 am »
Thanks guys.
