Substitute for lead shot
0 Members and 1 Guest are viewing this topic. Read 5392 times.
DARTH AUDIO
« on: 4 Oct 2004, 06:12 pm »
I need to fill the bass modules of my VR-4jr's. I don't want to use lead  shot. What else can be used to fill the bass module. I have heard of a steel/metal product that works just a well but I'm not sure who makes it or where to order it.
Thanks for the help,
Gary
R_burke
« Reply #1 on: 4 Oct 2004, 06:37 pm »
Not sure about the VR4 jrs, but I've used sand in tubular speaker stands and it works well.
cjr888
Re: Substitute for lead shot
« Reply #2 on: 4 Oct 2004, 06:42 pm »
Quote from: DARTH AUDIO
Gary
Micro-Bearing Conductive Steel Fill Material
http://www.audiopoints.com/micro.html
Great stuff.  Very fine.  Not cheap.  Used this in a pair of Osiris stands.  Give them a call and they will tell you their experiences for any speaker they've ever worked with and exactly as much as you will need.
Red Dragon Audio
    • http://www.reddragonaudio.com
« Reply #3 on: 4 Oct 2004, 06:42 pm »
How come you don't want to use Lead Shot?
Sand would be your best shot as an alternative to lead shot.  Plus it is quite a bit cheaper.
drphoto
« Reply #4 on: 4 Oct 2004, 08:37 pm »
If you're worried about contamination from lead, you can by steel shot or nickel plated lead. I think any gun supply store would have these products.
This type of steel shot may not have the specific properties of the micro-bearing stuff from Star Sound (audiopoints) but would be way cheaper.
Tonto Yoder
« Reply #5 on: 4 Oct 2004, 08:53 pm »
Some time ago, I had trouble even finding ANY shot locally; everyone said "Go to a gun shop" but I only found one 25 lb bag (for $25).
There's the nickel-plated stuff
that would seem to be safe(r).
I thought there was something special about lead that made it especially
good for filling stands/speakers????
Mad DOg
« Reply #6 on: 4 Oct 2004, 09:02 pm »
Quote from: Tonto Yoder
FYI...shipping on shot is quite expensive...
what makes lead "special" is that it has higher density than steel or any other shot.
Mad DOg
« Reply #7 on: 4 Oct 2004, 09:04 pm »
Gary
Gary,
Kevin @ VSA recommends 50 lbs of lead shot per bass module...of all the shot that is available, lead is the least expensive at around $1/lb...however since you'll need 100 lbs, it'll still be $100! :o
if you choose steel shot, it'll cost you even more.
Mad DOg
« Reply #8 on: 4 Oct 2004, 09:08 pm »
Gary,
Are you bi-wiring your 4jrs?
Tonto Yoder
« Reply #9 on: 4 Oct 2004, 09:12 pm »
I ended up stumbling onto a lead shot "recycler" in a nearby town: it's shot that's collected from shooting ranges, cleaned up and re-bagged.
It was around $12/ 25# bag.
Red Dragon Audio
« Reply #10 on: 4 Oct 2004, 10:00 pm »
Yeah I only paid $13 per 25lb bag of lead shot.  It came in a variety of sizes too.  From large rounds to very small rounds (think small like ballpoint pen tip and even smaller).
Don't worry about lead poinsoning.   As long as it is inside the woofer module, you won't have any problems.  Just don't sprinkle it on your Cheerios for breakfast and you'll be fine.
Fife12
« Reply #11 on: 4 Oct 2004, 10:05 pm »
Would cheap play sand from Home Depot not work?
DARTH AUDIO
« Reply #12 on: 5 Oct 2004, 12:17 am »
Thanks for the suggestions.. Lead shot it is.
Mad Dog, Yes they are bi-wired using the new Jolida JD3000 monoblocks. These amps could be the best kept secret!!
Thanks again,
Gary
maxwalrath
« Reply #13 on: 5 Oct 2004, 12:30 am »
Darth, completely off the topic, what amps have you used in the past? I think you've been through a few changes lately and was wondering what you're comparing the Jolida to in your system.
Christof
« Reply #14 on: 5 Oct 2004, 12:39 am »
Is the point of the lead shot just to add mass and lower the res. freq. of the module?  I was under the impression (maybe the wrong one) that acoustic energy should be turned into heat through friction inorder to be stopped.  Will lead shot allow for much friction vs. something like dry sand?  Just curious.
c.
Mad DOg
« Reply #15 on: 5 Oct 2004, 12:55 am »
darth audio,
the 4jrs are quite impressive speaker once the datalink is removed and they're bi-wired.
the jolidas sound interesting...will have to take a look into them... :)
DARTH AUDIO
« Reply #16 on: 5 Oct 2004, 01:37 am »
Max, I had the Spectron Musician III, listened to the Rogue M150's, a few of the "well Known" tube amps. The Jolida JD3000 has such a sweet sound, very natural. The midrange is too die for. These amps are 200 watts a side using (2) 211 tubes(Sino), (2) EL 34's(Svetlana's) and 2 AT7's(NOS Mullards) per monoblock. I think the Spectron is a great amp.. and I listened to many other "digital"amps. I went back to tubes and couldn't be happier.  :D My system is now all tubes. Just had my EAR 834p phono stage modified and it's using cyro'd Mullaed CV4004 and my Jolida JD100 just came back all modified using cyro'd 12AX7's in it. I love the sound of Mullards.
Gary
Mad DOg
« Reply #17 on: 5 Oct 2004, 01:49 am »
Max, I had the Spectron Musician III, listened to the Rogue M150's, a few of the "well Known" tube amps. The Jolida JD3000 has such a sweet sound, very natural. The midrange is too die for. These amps are 200 watts a side using (2) 211 tubes(Sino), (2) EL 34's(Svetlana's) and 2 AT7's(NOS Mullards) per monoblock. I think the Spectron is a great amp.. and I listened to many other "digital"amps. I went back to tubes and couldn't be happier.  :D My system is now all tubes. Just had my EAR 834p phono stage modif ...
4jrs in an all toob setup? :thumb: now that's gonna DEFINITELY sound very sweet! :dance:
if i recall correctly, you had the EE MiniMax preamp before? are you still running that? or was that someone else?
DARTH AUDIO
« Reply #18 on: 5 Oct 2004, 01:09 pm »
Mad Dog, I'm using the deHaviland Ultraverve JR. This preamp has BIG sound from Big tubes. Works great with the Jolida JD3000 monoblocks.
