Trying to pick out a budget cartridge for Rega RP-1
0 Members and 1 Guest are viewing this topic. Read 3492 times.
Yomaha
« on: 16 Jun 2015, 09:54 pm »
Hi everyone,
I have a Rega RP-1 and I need to upgrade my cartridge.  I would like to keep the price below $250 if possible.  I also want to buy thru my local hifi guy in Pasadena because they are super cool, have excellent service, and they do a free install and calibration of the cartridge if purchased from them.
They have the following brands: Grado, Sumiko, or Ortofon.
I was thinking either Grado Green, Sumiko Pearl or Ortofon Blue.
Any input on those or other models within those brands is appreciated!
Current System:
Rega RP-1
Bellari VP130 Phono Pre
Van Alstine Synergy SL Pre
Van Alstine Synergy 240 2-ch Amp
Salk Songtower RT's
Charles Calkins
Re: Trying to pick out a budget cartridge for Rega RP-1
« Reply #1 on: 16 Jun 2015, 10:04 pm »
Give Frank a call. Wayner does his cartridge work for him. I'm sure they'll be able to set you up with one.
                                                     Cheers
                                                     Charlie
audio.bill
« Reply #2 on: 16 Jun 2015, 10:43 pm »
I'd go with the Ortofon Blue, since it's right in your price range and is known to be a good match with the Rega. The Grados are nice but known to be prone to hum issues with the Rega tables due to positioning of the motor.
jarcher
  • It Just Sounds Right
Re: Trying to pick out a budget cartridge for Rega RP-1pp
« Reply #3 on: 17 Jun 2015, 12:32 am »
Of the three I'd second the ortofon 2m blue. Just make sure to give it at least 10hrs and preferably 100hrs before reaching a final conclusion. It can sound somewhat bright and unrefined before then. If your dealer has a break in record he can run it on or lend you, that will help to reduce the wait.
Wayner
« Reply #4 on: 17 Jun 2015, 09:43 am »
The Grado will hum on a Rega. Not a good choice for this table.
Wayner
Yomaha
« Reply #5 on: 18 Jun 2015, 12:08 am »
Thanks for the feedback - all duly noted!
steve f
« Reply #6 on: 18 Jun 2015, 12:26 am »
Consider the Shure M97Xe too.
simoon
« Reply #7 on: 23 Jun 2015, 08:11 pm »
Hi everyone,
Must be Brian Berdan at Audio Element!
Great guy, great shop.
KR500
« Reply #8 on: 3 Jul 2015, 07:36 pm »
Slightly off topic but i see you are using the Bellari VP phono preamp.
I did a bunch of tube rolling with NOS and current production tubes and had the best results with the..... ( wait for it )
Sovtek 12AX7LPS
It is the one pictured in the company schematic and sounds the best.
My dos centavos
Good luck with your cart search . I started with the Rega Red cart then went to the Elys
The Shure 97 mentioned by another poster is an excellent budget cart
Thugbee
« Reply #9 on: 24 Jul 2015, 07:31 pm »
Re: Sovtek
Would that be the 'straight' Sovtek or the "BLACK SABLE Sovtek 12AX7LPS"
KR500
« Reply #10 on: 26 Jul 2015, 12:31 pm »
Hmm... don't know about a Black Sable version ?
I got my 12AX7LPS from the US Sovtek dealer
Guess I'll duckduckGo the Black Sable  term and find out about it
I was surprised the Sovtek sounded better than the NOS and JAN tubes like Sylvania Phillips , GE etc. I tried
Also several JJ versions that I purchased from Eurotubes quite a while ago
Nick77
« Reply #11 on: 26 Jul 2015, 01:16 pm »
Any updates? I just pulled the trigger on a slightly used 2M Blue and wondering what choice you made?
