0 Members and 1 Guest are viewing this topic. Read 4402 times.
Blue Mike,I just read up on your speakers. They must sound wonderful.They're 140 lbs each, correct? If these were my speakers, I'd build a 'coffin' for them using 2x4s frames wrapped by 1/2" plywood. I'd wrap each speaker in a 2" thick foam blanket, secured with tape or straps. Id then wrap this in moving blankets before placing them in their boxes/coffins. I'd attach robust handles to the outside of the boxes and get three helpers to move them out of my house to the vehicle. Same to move them to the new home. With four bearers the load is well distributed.Alternatively, attach heavy duty castors to the bottom panel to make moving much easier if terrain allows.Just my two cents. Best of luck.Michael
Thanks guys for the tips Would wrapping the speakers in regular stretch plastic wrap be ok how is the uline product any different Yes they are 140 lbs each and awkward to handle perhaps looking at piano movers to move them depending on how expensive that is
Thanks where do I get polyethelyne sheets
