SOLD- Wyred4sound STP-SE with Level-2 mod- SOLD
0 Members and 1 Guest are viewing this topic. Read 1529 times.
RPM123
« on: 13 Jun 2015, 03:54 pm »
SOLD    Moving back to a tube based system, hence the sale. I had this preamp for about a year when I decided that I would have it modded through Underwood HiFi/Parts Connexion last year. In addition to the Level 2 mod, I also had a Furutech fuse installed. The mod takes an already excellent preamp and makes it even better with a fuller and more engaging sound! Also, a very transparent sounding preamp with a lot of functions that works very well with a wide variety of amps, both tube and solid state. (Works great with the JOB 225 amp! Unit is an easy 9 and works flawlessly. SOLD
Nice professional  reviews: http://www.6moons.com/audioreviews/wyred2/preamp.html
http://www.highfidelityreview.com/wyred4sound-stp-se.html
http://www.stereotimes.com/amp082912.shtml
From the Underwood ad:
The following details the Level-1 modification:
a) We add 1 DEXA Technologies “discrete” DUAL op amp module to the input buffer.
b) We upgrade 4signal path resistors with KIWAME 2-watt 1% Carbon Film resistors
c) We upgrade the power supply regulators with 2 DEXA Technologies “discrete series” regulators (+ & - 15V)
d) We replace the inexpensive AC connector with a FURUTECH Rhodium-plated AC inlet
e) 10 feet of WBT Solder is used throughout the mod
f) 4 hours labor are required to complete the mod
Sonic changes of our Level-1 mod: Better low-level detail and 3D ambiance retrieval Macro dynamics are improved It seems to play louder, with improved microdynamic contrasts
Midbass is improved to add weight to voices and make them sound more real
The midrange is a little more liquid than the stock machine's Imaging is more defined, soundstage depth is enhanced
Bass extension and impact are improved with more weight and authority
The high frequencies are a little smoother
Prices
The Level-1 modification to your preamp is $750.00 + freight
New modified preamps are available for $2,595.00 + freight
One year warranty on mod work to your preamp.
New preamps have a 1 year Underwood warrant
We also have a Level-2 modification that is more comprehensive at $1,400.00 to your machine. New Level-2 modified preamps are $3,190.00+ freight.
The Level-2 takes all of the level-1 and adds:
1) Two additional DEXA Technologies “discrete” DUAL op amp modules. One for each output buffer.
2) 6 Mundorf AG-Series main Power Supply filter caps at 22,000uf 25V each
The L-2 modified preamp is superb and better than most $6-10k solid state preamps.
STP-SE Specs:
Typical THD+N 20Hz-20kHz (A Wt) @ 2V: <0.003%​ Noise (A Wt / Vol ≤ 63): < 6µV Noise (A Wt / Vol ≥ 64): < 18µV Noise 20Hz-20kHz (Vol ≤ 63): < 9µV Noise 20Hz-20kHz (Vol ≥ 64): < 27µV Frequency Response 20Hz-20kHz: ± 0.020db Channel Tracking (All Steps): < ± 0.050db IMD: < 0.002% Crosstalk 20Hz-20kHz (Vol ≤ 63): > 106db Crosstalk 20Hz-20kHz (Vol ≥ 64): > 96µV Output Impedance (Vol ≤ 63): 113Ω Output Impedance (Vol ≥ 64): 78Ω Input Impedance: 60.4kΩ 6db gain Maximum Output Voltage: 9V RMS
« Last Edit: 23 Jun 2015, 09:49 pm by RPM123 »
RPM123
Re: FS - Wyred4sound STP-SE with Level-2 mod
« Reply #1 on: 22 Jun 2015, 06:18 pm »
Bump
