Clarinet, skipping the balance control
0 Members and 1 Guest are viewing this topic. Read 4115 times.
Bequerel
« on: 3 Oct 2004, 02:58 pm »
Would a 100k log pot be OK if I skip the balance control in the Cornet. (The schematic calls for a 50k balance, and a 50k log pot for main attenuation.)
hagtech
« Reply #1 on: 4 Oct 2004, 06:45 am »
Yes, you can use a 100k pot.  Just jumper across the balance control.
jh :)
Bequerel
« Reply #2 on: 4 Oct 2004, 06:56 am »
Great, Jim :D
tanchiro58
Skip balance control in Clarinet
« Reply #3 on: 28 Sep 2005, 09:43 pm »
Hi Jim,
I will try to replace a volume control with a 24 stereo stepped attenuator 100K but I got confused that how do you jump across the balance control. Stereo attenuator has two layers which wires should I connect to a first layer and which wires to a second layer? (I did not assemble the Clarinet). Thanks in advance.
Tan
hagtech
« Reply #4 on: 29 Sep 2005, 05:08 am »
Bypass balance control like this...
jh :)
LFE
« Reply #5 on: 2 Oct 2005, 04:31 pm »
If you skip the balance control, do you have to then use a 100K volume pot?
bluesky
« Reply #6 on: 2 Oct 2005, 07:33 pm »
Hi Jim
I too, hope to replace the "standard" volume control with a PEC unit I bought from DIY Hifi Supply and would like to know which row of three contacts connects to which on the PCB.
Has anyone tried those Cree diodes yet?
Cheers
Bluesky
tanchiro58
Clarinet upgraded with attenuator stereo
« Reply #7 on: 3 Oct 2005, 09:33 pm »
Hi Jim,
Thanks for your help. I have already done the jumping across the balance control like you draw. But I also got confused when I took off the volume control I do not know how to solder from the bypass balance to the stereo attenuator (six posts) since I see only three wires came out of balance control. Would you please help me to solve this problem once again? Many thanks.
Tan
hagtech
« Reply #8 on: 4 Oct 2005, 06:05 am »
Volume control is a little odd.  Not the pinout one would expect.  Try this:
jh :)
