0 Members and 1 Guest are viewing this topic. Read 4811 times.
No I am just curious, not using on anything right now. Essentially the higher frequencies would follow the path of least resistance or less capacitance in this case as the smaller cap will release the signal a bit faster making a certain range smoother and faster pushing the signal.
I understand that. I used it as and example to express the behavior of the frequencies.
Undertow,Subjectivists need to find some technical explanation for what they're hearing. When they can't you get silly analogies like "clearer windows into the music."Unfortunately, this is one of those topics that's been horribly skewered by audiophiles. Even the label "bypassing" is completely inaccurate.I suggest to step back and consider this topic anew. SS, as usual, is right on the mark with his technical explanation. That's an excellent place to start.Dave.
And objectivists say silly stuff like "if it measures the same then it sounds the same". The rest of your post was good, why start it off by denigrating the majority of people that enjoy this hobby?
"The whole topic is a can of worms."speedskater posted that with a 100-1 (say 1uF bypassed with .01uF) ratio only 1% of the signal will pass through the bypass cap. If this is true in the real world, it would suggest to me that adding a bypass is meaningless, right, or does that 1% really matter?
