Upgrade crossover for magnepan mg12
0 Members and 1 Guest are viewing this topic. Read 2134 times.
ryno
« on: 6 Jun 2015, 07:30 pm »
Bought from sonic craft, maybe 10 years ago.
Alpa core 12g 2.7mH foil coil and 50uF axon on the lows
Sonicap 30uF and 3uF on the highs
Not sure what the binding posts are
~2 foot reality cables with generic gold connectors
I removed the square plate with the binding posts/fuse and mounted a similar sized 1/8 inch hardboard and connected the reality cables directly to the drivers.
To do this I removed the sock staples on the bottom, and pulled the sock up far enough to make the connection.
DIY mitered cherry boxes with painted bases.
No PayPal charge, you pay actual shipping.
Any ideas on how to pack these? The caps are siliconed to the box lids, the coil sits on a felt pad with a dowel holding it in place. I worry about shipping as is, if the dowel snaps, a large coil would cause some havoc.
I went to a pair of 1.7's
$100 plus shipping, Ryan
ryno
Re: Upgrade crossover for magnepan mg12
« Reply #1 on: 5 Feb 2017, 09:42 pm »
Forgot I still had these. Or best offer.
earforce
« Reply #2 on: 9 Jun 2020, 11:28 am »
Is it still available? PM sent.
