SOLD: Vandersteen VCC-5 Center Channel Speaker -- Mahogany Walnut
0 Members and 1 Guest are viewing this topic. Read 977 times.
skriefal
  • SLC, Utah
About 1 year old.  I'm the original owner.  Speaker is in great shape with the exception of one veneer scratch near the upper left edge on the rear of the speaker (see photo).  Mahogany Walnut veneer finish.
The VCC-5 is a great companion to your Vandersteen 2CE, 3A, or 5A main speakers!
Will ship in original box and packaging materials.
$1500 + shipping !SOLD!
VCC-5 Specifications:
   Coaxial Midrange/Tweeter -- 6.5” Mineral-Filled Polycone with Die-Cast Basket with 1” Critically-Damped Alloy-Dome Tweeter
   Woofer(s) -- (2) 6.5” Mineral-Filled Polycone with Die-Cast Basket
   Recommended Amplification -- 100-200 Watts Into 8 Ohms
   Frequency Response -- 50Hz – 30kHz +/- 2dB
   Sensitivity -- 85 dB, 1 meter with 2.83 volt input
   Impedance -- 6 ohms nominal 4 ohms minimum
   Crossovers -- First order/6dB per octave, 150Hz, 3.5kHz
   Input Terminals -- Barrier strips, 7/16" max width
   Dimensions (WHD) -- 24” x 9 3/4” x 18”
   Weight -- 68 lbs. Net
   Country of Manufacture -- Made in the USA
« Last Edit: 2 Jun 2015, 12:52 am by skriefal »
