something doesn't like each other????
0 Members and 1 Guest are viewing this topic. Read 1335 times.
tripwr1964
« on: 31 May 2015, 02:18 pm »
thought i'd try plugging my gallo subamp into my gallo 3.1's the other day and got a horrible buzz out of speakers (sa not even on).
pre is a Decware csp3 using the mono output and Y-rca to gallo SA.
the stereo outputs going to khartago monos.
I've used this subamp many times with various stereo amps with no problems.
It also works ok with driving a passive subwoofer using the decware mono output.
something about the csp3 and mono amps not liking the gallo sa????
RDavidson
Re: something doesn't like each other????
« Reply #1 on: 31 May 2015, 04:37 pm »
With the amp not even on, I'd say you must have a grounding issue somewhere. You might try using a ground lift "cheater" plug on the power cable of the SA amp.
tripwr1964
« Reply #2 on: 31 May 2015, 09:06 pm »
Yes good idea.  Thats kinda what I was thinking too.
