SOLD: Musical Fidelity M1ViNL Phono Stage
0 Members and 1 Guest are viewing this topic. Read 566 times.
skriefal
  • SLC, Utah
« on: 31 May 2015, 02:18 pm »
Works nicely.  Rated 7/10 due to marks on top of unit and lower left corner of front panel (see photos).
Supports moving coil and moving magnet cartridges.  Balanced and single-ended (RCA) outputs.
I do not have the original box or manual.  Will pack securely in a replacement box, and will include a basic power cord.
$660 + shipping SOLD!
Product highlights:
    compatible with moving magnet and moving coil phono cartridges
    seven capacitance and two impedance input settings for matching moving magnet cartridges
    ten input resistance settings for matching moving coil cartridges
    switchable RIAA/IEC equalization curves to eliminate low frequency rumble from turntable or disc imperfections
    all settings adjustable from front panel during playback
    RCA and balanced XLR outputs for versatile connections to virtually any system
    12-volt trigger input and output for custom installations
    frequency response: RIAA or RIAA/IEC (selectable) ±0.2dB (MM and MC)
    signal-to-noise ratio: greater than 90dB (MM), greater than 88dB (MC) A-weighted
    THD at 1 kHz: less than 0.01% (MM and MC)
    input sensitivity: 3mV in for 300mV out (MM), 500uV in for 300mV out (MC)
« Last Edit: 13 Jun 2015, 02:46 pm by skriefal »
