Integrating your VMPS Sub in an Audio/HT dual system
0 Members and 1 Guest are viewing this topic. Read 2001 times.
John Casler
I've been reading in a couple threads here about some of you with HT/Audio systems (where the two systems are one and the same) who are working on integrating your subs.
Some time ago, when I had my systems together, I used a set up that worked pretty well.
For this system to work you need:
1) a seperate preamp
2) a receiver or pre/pro with good bass management
Now the main focus here is 2 channel sub integration since the receiver-pre/pro already takes care of that for the HT,
The 2 channel wiring set up looks like this:
cd/dvd player analog out > 2 channel preamp > L&R amp channels > L&R speakers
then to get the ability to use the bass management of the receiver PrePro:
cd/dvd player "digital out" > receiver pre/pro input > LFE output > Sub or Sub amp
With this set up all you do is have your receiver or pre/pros L&R outs go to the 2 channel pre amp's "aux" input, rather than directly to the amp.  Then when listening to HT, simply set the 2 channel preamp to "aux" and adjust the volume to a "pre selected" level that you determined during HT set up.
Now with this set up you have the ability to use the bass managment "only" for the sub when you are using the 2 channel only system, since the 2 channel system uses the cd/dvd players "analog" outputs and the HT system uses the cd/dvd players "digital" outs.
This allows you to not only select any x-over frequency available to "ramp" the sub in, but also the volume control to "adjust" the exact bass level for each CD.
It "does not" offer "high pass" for the L&R, only allows for the HT receiver/prepro to be used as a bass filter and volume control.
While a good, high quality X-over is always the best choice, this offers a "workaround" with pretty good results.
PLMONROE
« Reply #1 on: 2 Oct 2004, 08:43 pm »
How would one integrate the Trinaural processor into such a set up such as this?
Paul
John Casler
« Reply #2 on: 2 Oct 2004, 09:10 pm »
Quote from: PLMONROE
Paul
The TNP has its own built in x-over and instructions for HT intergration can be found here in the owners manual:
http://www.ampzilla2000.com/trinaural_manual.html
jermmd
« Reply #3 on: 2 Oct 2004, 10:17 pm »
John,
I like that set up.  Thank you.  I didn't want to interrupt the 2 channel chain with my pre/pro and your solution works perfectly.
Joe M.
John Casler
« Reply #4 on: 3 Oct 2004, 12:32 am »
Quote from: jermmd
John,
Joe M.
 :mrgreen:  :mrgreen:
