How much current does my Kismet Stereo Amp draw?
0 Members and 1 Guest are viewing this topic. Read 3034 times.
firedog
« on: 27 May 2015, 08:45 am »
Klaus says the amps draw about 30 watts at idle. Does anyone know approximately how much they draw when working hard?
To get the Amps (current) draw, I divide the amount of Watts drawn/Voltage on the line, correct?
GentleBender
« Last Edit: 27 May 2015, 01:24 pm by GentleBender »
firedog
TAULISA
Re: How much current does my Kismet Stereo Amp draw?
« Reply #3 on: 27 May 2015, 11:25 am »
Whatever your Kismet Stereo Amps draw, remember as follows:
GentleBender
« Reply #4 on: 27 May 2015, 01:28 pm »
yeah sure, if I had one. I just need an approximation.
There are many variables that would make an approximation tough. What is the nominal load of your speakers and their sensitivity? Things that the Kill A Watt would be able to answer. Maybe someone else here will have more helpful info... :?
firedog
« Reply #5 on: 27 May 2015, 04:42 pm »
nominal load is 8 ohm (probably ranges 6-8 ohms)
sensitivity is about 90db
firedog
« Reply #6 on: 27 May 2015, 04:43 pm »
Klaus, like many other amp producers, recommends leaving the amps on 24/7/
marflao
« Reply #7 on: 28 May 2015, 07:31 am »
I don´t have a Kismet in place but maybe my findings for the Cyclops (connected to a pair of Kef Q5 - 8 Ohm impedance, 91db sensitivity) gives you an approximate value:
- idle: ca. 42W +/- 0.4W
- working (volume knob at  9 o'clock): no difference than in idle
- working (volume knob at 11 o'clock): peak reached 48W
Of course this also dependent on the song. For the values above I used Grandbrother´s "Ezra was right".
Edit: just forgot to say...i used a kill-a-watt ;-)
firedog
« Reply #8 on: 28 May 2015, 02:13 pm »
Thanks for that.
macrojack
« Reply #9 on: 28 May 2015, 02:18 pm »
You might look to your public library. Where I live the public library keeps at least one Kill-a-Watt for lending purposes. You can borrow it with your library card. Maybe that is possible in your area.
I don't know why you want to know this information but I commend you for caring enough to find out.
